Bottlehead Kits => Crack => Topic started by: deaton on July 06, 2014, 11:23:21 AM
I finished my Crack build a couple of nights ago and both the resistance checks and voltage checks were fine. I fired up the amp and listened to it for about an hour and everything sounded great. I flipped the switch today, two days later, and the amp would not turn on. The tubes weren't glowing and the LEDs on the bottom of the A socket were not lit.
I did a resistance check and all checked out. I did a voltage check and was getting very high voltage readings on the terminals that should have voltage on terminal 1-6 as shown below. I wasn't getting any voltage on terminals 7 and 9. When I got to terminal 13 and 15, they were also reading high. On a second reading of terminal 15, I must have shorted something with the probe as there was a pop and spark at the cap.
Terminal voltage
1 224
2 230
3 0
4 229
5 225
6 0
7 0
8 0
9 0
10 0
11 0
12 0
13 230
14 0
15 229
After the spark, I repeated my voltage measurements and now, all the voltages are low and falling as I continue to probe through the board. They started at about 11V, and by the time I got to the end of the measurement, the terminals were all showing 0 volts. Terminals 7 and 9 were still showing zero when others were showing less than 1V.
1 11.2
2 10.4
3 0
4 9.4 and dropping
5 8.4 and dropping
6 0
7 0
8 0
9 0
10 0
11 0
12 0
13 3.8
14 0
15 0.5
20 0
21 0.6
a1 0.7
a2 0
a4 0
a5 0
a6 0.5
a7 0
a9 0
b1 0.4
b2 0
b3 0
b4 0.4
b5 0.4
b6 0
b7 0
b8 0
Any ideas what might be wrong? I've checked out all the diodes with the meter and they all check fine. Caps are all oriented correctly. Everything was working great for an hour!
I pulled the fuse after the second set of voltage measurements and found that I had blown the fuse when I got the spark testing terminal 15. That explains the dropping voltages as the caps slowly discharged. But I'm still perplexed as to why the voltages were so high on the first reading and am not sure which part of the circuit to check.
After replacing the blown fuse and measuring all voltages again, this is what I'm seeing:
Terminal Measured Reference (from manual)
1 224 75-90
2 230 170
3 0 0
4 229 170
5 225 78-90
6 0 0
7 0 100
8 0 0
9 0 100
10 0 0
11 0 0
12 0 0
13 230 170
14 0 0
15 229 185
20 0
21 232 206
a1 226 90
a2 0 0
a4 0 0
a5 0 0
a6 226 90
a7 0 0
a9 0 0
b1 225 90
b2 230 170
b3 0 100
b4 225 90
b5 230 170
b6 0 100
b7 0 0
b8 0 0
The tubes are made to glow by the pair of twisted red and black wires that leave power transformer terminals 4 and 5, then go to B7/B7, then to A4/5/A9.
If both tubes don't glow, then the twisted pair going between the power transformer and B7/B8 isn't properly connected. (Or you may have accidentally cut one of the wires coming out of the power transformer)
That seemed to be the issue. Thanks for the advice. The solder joint on terminal 5 of the transformer was bad. Reworking that seems to have done the trick.
