Bottlehead Kits => Crack => Topic started by: Tom620 on July 10, 2014, 03:13:30 AM
Title: The best way to measure a tube.
Post by: Tom620 on July 10, 2014, 03:13:30 AM
Hi,
What is the best way to test the quality of the tubes without a tube tester?
According to Caucasian Blackplate:
The best way to measure a tube is to stick it in the Crack and measure the voltages at 1/5, listen to the amp for noise and distortion, and potentially put a 60Hz signal into the input and measure the AC voltage at pins 1/5.  This will give more reliable results than any tube tester I am aware of. By 1 and 5, I mean terminals 1 and 5, not tube socket pins 1 and 5.
http://www.bottlehead.com/smf/index.php/topic,3501.0.html
I understand this is for the 12au7, but what about the 6080 tube?
Title: Re: The best way to measure a tube.
Post by: Kris on July 10, 2014, 04:18:15 AM
for 12au7 see Crack FAQ (pt.10) here: http://bottlehead.com/smf/index.php?topic=4295.0
and as far as 6080 see this: http://bottlehead.com/smf/index.php?topic=6437.msg62978#msg62978.
Kris
Post by: porcupunctis on July 10, 2014, 10:26:44 AM
Just listen to it.  Best test ever.  You will gravitate to the best tube even if you don't know why.
Post by: Tom620 on July 12, 2014, 01:23:30 AM
Thanks guys :)
