Bottlehead Kits => Crack => Topic started by: Claudius on September 11, 2014, 12:28:40 PM
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FqH3aqeI.jpg&hash=08f2ab1a468242b3fc92b0dae5b88502a35acbb3)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FmF3hWtQ.jpg&hash=957381dca239bab1b7a461c301ae3def0bc09c4b)
I just finished my Crack and although the resistance check was fine, the voltage check came up with some problems, and the LEDs aren't lighting. I checked and tube heaters are getting the correct AC voltage, so I wonder if it's a problem with the input tube. The power tube lights up like a Christmas tree, but the input tube only has two tiny spots that glow.
1- 0
2- 0
3- 0
4-0
5-0
6- 0
7- 71
8- 0
9- 70
10- 0
11- 0
12- 0
13- 201
14- 0
15- 213
20- 0
21- 226
A1- 0
A2- 0
A4- 0
A5- 0
A6- 0
A7- 0
A9- 0 (multimeter clicks continually)
B1- 0
B2- 200
B3- 70
B4- 0
B5- 200
B6- 70V
B7- 0 (multimeter clicks continually)
B8- 0
As far as the tubes lighting up, your description seems normal. I know everyone will seem to tell you this but check your connections in the amplifier circuit.
Looks like you forgot the power supply wire from B2
I sure did--thank you!
I'm getting closer--but no cigar...yet. One LED is lit, but the one attached to A8 doesn't look like it lights.
1- 152
2- 170
3- 0
4-170
5-76
6- 0
7- 152
8- 0
9- 102
10- 0
11- 0
12- 0
13- 170
14- 0
15- 194
20- 0
21- 218
A1- 75
A2- 0
A4- 0
A5- 0
A6- 153
A7- 0
B1- 152
B2- 169
B3- 152
B4- 75
B5- 170
B6- 102
B7- 0
B8- 0
Do both halves of the 12AU7 glow?
Yes. The tops of the rods on both sides are glowing. Not very brightly, but evenly.
Try poking at the LED that isn't glowing with a wood chopstick (or stick from the yard, but not a wet one!) while the amp is running. You may have a loose connection that isn't allowing the 12AU7 to draw any current. Also gently poke each 22K resistor to see if the LED pops on.
I tried some gentle prodding with a chopstick on both the LED and 22K resistors--no change. I also reflowed the joints on both sides of the LED--no change.
You can temporarily solder a wire between A3 and A8, just to see what happens.
Ok, I jumpered A3 to A8 and checked the continuity to make sure the connection was good, but the A8 LED still isn't lighting.
With the jumper in place, what are the voltages at T1/T5?
T1- 123V AC
T5- 6.1V AC
Sorry, I should be more specific, what are the DC voltages at terminals 1 and 5 (outside lugs on the 5 lug strip at the 9 pin socket).
Ok, gotcha. 78V at both 1 and 5.
Alright, you can actually listen to the amp like that.
The non-glowing LED probably got broken or melted in the build, and will need to be replaced. You can e-mail replacementparts(aht)bottlehead(doht)com
Paul-- Thanks for all your help! I'll request a replacement LED.
I just plugged in my HD650s and the Crack sounds pretty good! Is it going to sound any different when I remove the jumper and replace the LED?
Probably not. In hypothetical terms, a shared cathode connection can lead to crosstalk, but the dynamic impedance of that particular red led is so low that this isn't realistically a problem.
Thanks, that doesn't surprise me, given how good it sounds in it's current state.
Hey guys
Thought I would comment here as I have a similar issue. I have manage to completely melt one of the LED lights. will it still work without this or should I just order a replacement ?
Replacing it is best even if the voltages still read correct. If the voltages are not correct you must replace it for sure. You can order some replacements at [email protected].
