Bottlehead Kits => Legacy Kit Products => Topic started by: guymsn on November 03, 2014, 11:11:46 AM
After a few years of storage my foreplay is only working on one side. tried swapping tubes and no luck. where should I start? Thanks for the help.
The first thing to do is check resistances against the manual. If that passes go on to the voltage measurements.
Post only those that are +/- 15% out of spec. Also post the expected measurement.
A quick check on the internet and I couldn't find the manual or test pages. Our home was wiped out in hurricane sandy with all my paper work thats why the foreplay hasn't been used. Where could I find that page? Thank you again for your help. This was a purely stock build with the gold rya upgrade and recomended dayton output caps. Regards
Just the voltages on the 9 pin sockets will be good enough. Pins 1, 2, 3, 6, 7, and 8 on each 9 pin socket will give an overall indication of operation.
