Bottlehead Kits => Legacy Kit Products => Paramount => Topic started by: wullymc on November 03, 2014, 03:12:18 PM
Title: Paramount voltage concerns **SOLVED!!**
Post by: wullymc on November 03, 2014, 03:12:18 PM
I have gone onto Voltages  (300B)
Right Monoblock:
 OA voltage stays at 351
Because the OA stayed high on the Right one I didn't proceed to do any more voltage checks.
Left Monoblock
OA goes down to 296.
I have a problem with OB.  I register a 0 and even if I adjust the potentimeter it stays at 0.
Terminal      Measured Voltage     Manual
1                       447                         440
5                       71                             71
9                         0                           200
10                       0                               0
16                     463                         457
17                        0                              0
18                        0                              0
19                        0                          200
A1                     74                            74.1
A2                    440                          440
A3                        0                           close to 0
A4                      69                            69.2
6V Red              2.6                           3.1
6V Black            2.6                           3.1
Kreg A side          0                            4.1
Kreg B side       16.3                          6.3
OA                     298                         300
OB                         0                         200
Kind of stuck as to where to go from here.
For R Block - problem with OA staying at 350=351
L Block major concerns:  OB, 9, 19, Kreg both A and B sides.
Any suggestions.  Thanks....Dave
Modify message
Title: Re: Paramount voltage concerns
Post by: wullymc on November 04, 2014, 02:30:18 PM
I have tried swapping the 5670 tubes to see if the OA voltage would be better in the Right Monoblock.
It still reads 350V and doesn't fall below after 20 seconds.  The manual says to check your wiring.  I will have to try to figure out why this would be.
If anyone has any suggestions to my 1st post or this I would appreciate the help.
Thanks...Dave
Post by: marantzfan on November 04, 2014, 02:40:57 PM
Perhaps if you posted some pictures of the underside of the amp it would assist others in helping you through the troubleshooting.
Post by: wullymc on November 04, 2014, 11:15:04 PM
Thank you.  I will post some pictures this weekend of the underside.
All LEDs are lit for both Monoblocks.  When I have time I will reflow all solder joints to see if this rectifies the problem.
I have checked older posts for these problems that I am having.  With the OA not going down 1 person had a 5687 tube in there instead of a 5670 tube.  That is why I swapped tubes.  The voltage stayed the same. As for the 0 voltage at OB I am checking R3, R4, 431 chip and -reg A and kreg A.  I will reflow all these and look at the connections to the tube socket.
I guess my not knowing is where/what provides the voltage to OA for the one that doesn't go down from 351?  In the voltage check it just states shut off and recheck wiring.  What I would like to know is where to look for the problem.    :)
Post by: Paul Joppa on November 05, 2014, 10:32:44 AM
Right monobloc - OA at 350v. =====================
OA feeds the regulator side of the 5670, specifically OA to plate (pin B6); the cathode (B8) goes through the 431 at kreg(B). Yes this is confusing, swapping sides - pay attention!
The regulator is protected by the Zener string which is why you see 350v. This indicates that OA is in fact feeding current to the Zeners, and thus the A side C4S (the portion near the center, with the LEDs and two transistors) is working.
Without a measurement of the kreg(B) voltage it's hard to know why the regulator triode is not drawing any current. You can check the cathode  and plate connections. Since all LEDs are glowing, I infer that the regulator bias string is intact - that's the two 149K resistors R2(B) and R4(B) and the 2.49K regulator reference resistor R3(B). You might make sure the 431 on the B side is correctly oriented and properly soldered.
If the above does not turn up anything, measure the voltages at kreg(B) and both ends of the resistor R3(B)
Left monobloc OB = 0 ==============================
OB goes to the driver triode plate, B4. Since the cathode of the driver, B2 and kreg(A) is also zero, I suspect the plate-OB connection. The most common cause is a poor solder joint at the collector (middle pin) of the MJE-5731A transistor. This pin is connected to the heat sink on the transistor, making it more difficult to get the pin hot enough for a good solder joint.
Post by: wullymc on November 05, 2014, 12:06:06 PM
Thank you sooooo much Paul.
You don't know how much I appreciate your input.
This is exactly what I wanted to hear.  Now I know where to go!! :)  I will probably tomorrow take the time to verify and resolder the areas that you have indicated.  I will also take readings at kreg(B) and both ends of R3(B).
Fingers crossed!
Take care...Dave
Post by: wullymc on November 05, 2014, 02:44:43 PM
Paul,
You sir are a genius!!!  L Block is good now.  I resoldered B4 and now I get the following:
OB          175
9             175
19           175
Kreg A     3
Kreg B     7
Thank you thank  you thank you.
Tomorrow I will work on the R Block.  Hopefully I will get that up and running!
Take care....Dave
Post by: wullymc on November 05, 2014, 04:17:59 PM
Couldn't wait to do the other Monoblock.
Resoldered B6, B7, & B8.  Checked voltages and everything works!!! Woo Hoo!
I wasn't able to get a shorting jack that I made to work so I haven't yet adjusted the hum pot.  I am going to hook it up and see how it sounds.....exciting.
Thanks again for the assistance.  Much much appreciated.
Listening now on cheap speakers to start...just incase.  Sounds really good.  Tomorrow I will hook them up to my Horns.  Currently being lead by a Quickie!.....
Super happy.  Thanks again!  :):):)
Darn it.  Left Monoblock lost music after 30 minutes.  WIll look into the voltages tomorrow on that one.  Good night!
Post by: wullymc on November 06, 2014, 05:02:50 AM
Well this morning I retook the voltages.
Everything was ok.
I plugged up the Paramounts to my good speakers.  I heard hum on both speakers so I adjusted the hum pots.  I thought this was encouraging to hear hum on the bad Paramount.  Unfortunately, when I played music no sound came out the bad paramount.
I swapped Tubes and still no sound.  I resoldered all the connections on the OT-1 and binding posts and made sure the wiring was correct.  No sound.
I saw Doc's post to thdewitt "
The next step is to take PB's advice to put a signal into the amp and trace it. You can check it at the center pin of the RCA, then measure AC voltage right at pin 3 of the 5670. If they aren't the same maybe the 220 ohm grid stopper resistor at pin 3 is damaged.
If they are the same, measure AC voltage at pin 3 of the big tube. It should be a lot bigger because the first tube will have amplified it. If it is not, once again make sure the 220 ohm grid stopper resistor at the pin is good. If signal is good all the way to that point, measure it at output transformer OT-1 terminal 7. Again, it should be a much higher voltage. If you don't see signal there check your output cap connections. If signal is good there, go over your output transformer secondary wiring and the binding posts."
Unfortunately, I don't get AC voltage using my meter at either Paramounts for the centerpin of RCA, B3, A3, or Terminal 7.  It reads 0.
I have used multiple sources, computer through DAC and Record.    The last time I looked at the bad Paramount the B side LED were not lighting up.  I will go come back either tonight or tomorrow and post some voltages.  I think I will also resolder B3.
Take care...Dave
Post by: Grainger49 on November 06, 2014, 05:15:53 AM
Did you try the good interconnect feeding the "bad" amp?  Just want to be sure you are getting a good signal to it.
Post by: wullymc on November 06, 2014, 06:22:28 AM
Thanks Grainger.
I tried the other interconnect and still no sound.  I just resolders B3 and the RCa jack.
Turned on the amp and all 4 LEDs were lit and I got 296 on OA and 442 on A2.  But when I went to OB it was at 89V.  I went to adjust it and then noticed that OB was 0 and the 2 LEDs on the B side were not lit.
Now I was getting 0 for 0A and on Kreg B.
I resoldered B6, B7, B8, &B4.
I restarted the Paramount and again all 4 LEDs were lit and I got 296 on OA and 442 on A2.  But when I went to OB it was at 89V.  I went to adjust it and then noticed that OB was 0 and the 2 LEDs on the B side were not lit.
Now I was getting 0 for 0A and on Kreg B and both sides of R3 (B).    I think I might call it a day.
I feel like I am so close but yet so far!....Dave
Post by: fullheadofnothing on November 06, 2014, 07:43:55 AM
Have you checked to make sure your jack isn't shorted? Measure the resistance between center pin and ground.
What signal are you feeding it? Is it a 60Hz sine wave? Some meters cannot read much in the way of AC that isn't the mains frequency they expect. If you haven't already, download a 60Hz sine to your computer or phone and use that as your signal. If you're still not getting a reading at the jack you may need to turn up the level on your source.
Post by: wullymc on November 06, 2014, 08:16:20 AM
Thanks for the input Joshua,
I tried the AC for both Paramounts (one of them works fine)  I did the 60Hz sine wave from my Computer & phone.   I hooked up the Paramount to my Phonopre/Quickie and played a record.  All were a no go.
Dave
Post by: fullheadofnothing on November 06, 2014, 08:40:27 AM
What is the resistance between hot and ground on the RCA?
Post by: wullymc on November 06, 2014, 09:50:01 AM
I have tested both Paramounts and both resistances indicate 1.
Dave
Post by: fullheadofnothing on November 06, 2014, 09:56:57 AM
Well, that ain't right. They should measure ~250KΩ. Either your meter can't read that high and 1 is how it shows "over limit," or it's reading 1Ω because it's shorted and your meter leads are close to 1Ω.
Post by: Paul Birkeland on November 06, 2014, 10:32:47 AM
You can also measure the AC voltage at the interconnect unplugged from your amplifier.  From your phone, you should see something like 200mV-1V.
Post by: wullymc on November 06, 2014, 01:40:56 PM
Hi Joshua,
Sorry you are absolutely right.  It measures 246K for me.
I still can't get any AC voltage check from the interconnect.  I have tried the 3.5mm to RCA cable from my phone and also the Interconnect coming from my Quickie that has my phono preamp/TT connected to it.  I don't know why.  I was able to use my DMM to get the AC for the 6V points on the big pcb in the Paramounts.  Confused.
...initially it played a good 30 minutes of music before it failed.
   Now when I take the voltages  OB is at 89 with all LEDS lit and when I try to adjust the potimeter it goes to 0 2 leds on B side go off and Kreg B is 0.
Post by: wullymc on November 07, 2014, 03:53:32 AM
Thanks for your patience with me guys.  I appreciate it.
I resoldered the middle joint to the MJE-5731A along with redoing B1, and 20L (that attaches to B3).
I have retaken the voltages and everything is fine now.  I have been monitoring OB for 5 minutes and it is steady and all 4 LEDs are lit.  Now I have just looked after 10 minutes and the reading on OB is now 38 and I get 0 for OA.   It is good initially then drops off.
Do you have any ideas what could make OB fade like that? Where should I look?
Thanks....Dave
Post by: Paul Joppa on November 07, 2014, 10:38:32 AM
Most likely a bad solder joint is failing when things heat up. See my previous post for some places to look and data to take.
Since this is possibly the second bad solder joint, you may want to re-flow all the solder joints on the PC board just to be sure, and to avoid diagnosing more of them one at a time. Remember, the soldering iron heats the terminals and wires; the terminals and wires melt the solder.
Post by: Doc B. on November 07, 2014, 12:49:13 PM
This is something that I try to convey with only moderate success. On average it is faster to reheat all the solder joints in an area of the amp where you are having a problem than by poking around and then reheating what you think might be the problem spot.
Post by: wullymc on November 07, 2014, 01:13:27 PM
Thanks guys for the help.
Tomorrow (I hope) I will take off the pcb and resolder/flow all the points.  At that point I will also take some pictures with my camera and upload them here.  Hopefully this will solve all the issues with this one.  When I was listening for the 30 minutes when both were working I was amazed at the resolution.  Really exciting.  Just can't wait to get this one going again.
If all else fails I will send this one to you for assistance.
Take care.  Thanks again for the support, encouragement, and patience!  I really appreciate it.....Dave
Post by: Paul Joppa on November 07, 2014, 03:42:35 PM
Patience is the key - diagnosis and treatment is sometimes painfully slow by forum posts, but we nearly always get there! Once you do get it stable, wait for the break-in; it will take 20-50 hours of music before the capacitors and transformers are sounding right.
Post by: wullymc on November 08, 2014, 12:53:05 AM
Thanks Paul.
I couldn't wait until tomorrow.  Kids are asleep!
I took off the pcb and resoldered all connections.  Soldered the pcb to the correct locations..on the B terminals and 16 & 17.
Did my resistance checks:
         reading           Manual
1       infinity               *
5          999               1K
6        1115              1118
7          247K              249K
9       infinity              124K *
10          0                    0
11     infinity               3.0M
12     infinity               5.6M
13          0                     0
14     infinity               9.2M
15     infinity               15M
16      increasing          *
17         0                      0
18         0                      0
19       infinity             128K *
20        247K              249K
A1        1013              1027
A2      infinity                 *
A3        247K               249K
A4        1013               1028
B1          0                    0
B2         7.96K              8.2K
B3         247K              249K
B4         296K              130k *
B5           0                     0
B6         349K              177K  *
B7         235                220
B8        1188K               *
B9           0                    *
Voltage checks:
OA          0 - 3              296
A2          447              440
OB            0                175
1            446              440
5              71                71
9               0               175
10             0                  0
16           468             457
17              0                  0
18              0                  0
19             0                175
A1           73                74.1
A2         442               440
A3             0                   0
A4           68                 69.2
6V red     2.6                3.1
6V black  2.6                3.1
Kreg (A)    0                 4.1
Kreg (B)    0                 6.3
OA            0                300
OB            0                175
Darn it.  No voltage now at OA!   :o    Both LEDS on the A side lite up the B side LEDS do not lite up.
I am attaching some photos showing the resoldering and the steps to connect the pcb to B2, B4, B6, B8, 16U, 17U.
Any suggestions for getting OA back working?
Thanks again for your help....Take care...Dave
Post by: wullymc on November 09, 2014, 05:37:55 AM
I found this post from PJ for a person that was having 100V at OA:
"If the B side LEDs are not lit up, then there is no current running through them. From the diagram, you can see that the 100v you have goes through the LEDs, then 149K R2(B), then through 149K R2(B), then 2.49K R3(B) to ground. One of those connections is broken, presumably - or else the LEDs are in backwards.
It's the voltage dropped across the 2.49K resistor R3(B) that sets the shunt regulator voltage, so there's no surprise that voltage is not correct. It's possible (for example) that an error on this chain could damage the B-side 431 and short it, which would lead to about 100v on the shunt reg triode.
You can check the voltages on the varios resistors mentioned above, and on the 5670 pins 6, 7, and 8. This should give us more clues."
I have taken the voltages and am getting 0s across the board.  Unless anyone has any suggestions... I think I am done.  I have tried my hardest & done what research I can try to get this going.  I don't know what else to do.  I need someone to take this off my hands. :(
Its hard to take from listening to it for 30minutes and then feeling so far away from getting it to work.  I was ready to buy a Beepre to pair this with but if I look at the photo it looks about 10 times harder.
If it is okay I think I am ready to send it in for professional assistance.
Take care...Dave
Post by: Paul Birkeland on November 09, 2014, 08:17:26 AM
0V at OA would suggest that either the center leg of the MJE5731A isn't well enough soldered, or that two adjacent pads on the PC board got soldered together by accident when you went back to reheat the joints.
It's also entirely possible that one of the wires going to the board itself is a little loose, particularly the ground wire that would feed BA/BB.
Post by: wullymc on November 10, 2014, 02:38:55 AM
Thanks PB,
Tried what you recommended.  Same result.  :(  I would like to send it to you.
Thanks....Dave
Post by: wullymc on November 11, 2014, 05:32:10 AM
hi,
I took off the pcb again and warmed up the solder joints.
I am ready to reattach it to the Paramount.  I am attaching pictures if anyone can see any problems.
Is there any way to test voltages without attaching it (ie. use a battery?).  Probably not but wanted to ask.
I have used my meter to check continuity and everything seems ok.  Does continuity indicate a good solder joint if you are measuring between the 2 solder joints (not the wires)?
Here are the pictures.    Really want to try to get this to work without sending it in but will if necessary.
Thanks...Dave
Post by: Paul Birkeland on November 11, 2014, 05:53:02 AM
The battery voltages would have to be pretty high to get the board to function, and you would have to simulate loads with large resistors, so it ends up getting complicated.
Other than some of the leads poking out on the bottom of the board being a bit long, it looks like that board should work well.
Do also bear in mind that a loose wire going from the board to the terminal strips/tube socket could cause your issue.
Post by: wullymc on November 11, 2014, 02:48:14 PM
Thanks PB!
Well I reheated everything on the pcb and resoldered a couple of connections.  i reattached everything to the Paramount.
Took voltages and everything is good!  YAY!!!!
Waited 20 minutes, connected speakers and I have sweet music!!  YAY!  I listened for 1 hour.
Thanks again for your posts, without you and Paul Joppa's suggestions I would have been really stuck.
The only thing is when I power on the amp I get a "FFFFFFFFFFFFFFFF" sound for about 1 second.  After it is fine and there is no problems afterwards.  Do you have any idea what this could be?
Thanks again!...Dave
Post by: Grainger49 on November 11, 2014, 03:16:06 PM
Dave,
When you check  continuity from the newly installed boards to the terminals or tube pins try checking from a component lead that is attached to the input/output/ground solder tab to the metal of the terminal or tube pin.  Don't check from solder to solder.  That can give you a false sense of security with the solder joints.
I have been bit in the butt by just this.  So now I "ring out" from a component to component.
Good luck!
Title: Re: Paramount voltage concerns **SOLVED!!**
Post by: wullymc on November 12, 2014, 04:15:26 PM
Thanks to everyone that contributed to this thread.
I am very happy to report that everything is working now!  I have about 3 hours on both amps and everything is great.  I had a problem with a FFFFFFF sound when I turned on the left one but that disappeared after 3 turn ons.  I don't know if it was just something that needed to burn in a little bit?  I don't know.
Anyway, thanks again for your patience with me!  I am so happy!
Take care.  Wishing everyone well.
Dave
Post by: Paul Birkeland on November 14, 2014, 07:24:29 AM
There are some warm up noises with the Paramount, which shouldn't be of concern.  There will be a little rustling usually, and actually a funny chirp that happens when the 431 regulator begins to operate.
