Bottlehead Kits => Eros Phono => Topic started by: keithp on December 19, 2014, 12:47:34 PM
Title: MJE350 orientation
Post by: keithp on December 19, 2014, 12:47:34 PM
I am building the Servo PC board for the Eros and the directions say to orient the two MJE350 transistors with the metal sides facing away from each other.  The current version of the MJE350 transistor no longer has metal on one side. Should I assume the "non-printed" side of the current version is equivalent to the metal side on the previous versions?
Title: Re: MJE350 orientation
Post by: mcandmar on December 19, 2014, 01:20:11 PM
You got it, the part number side is the same.
