Bottlehead Kits => Crack => Topic started by: jazzfan78 on January 29, 2015, 01:06:53 AM
here is my voltage results. are they ok? i put in () what should be in manual
1 98 (75-90)
2 157.7 (170)
3 0 (0)
4 157.5 (170)
5 87.9 (75-90)
6 0 (0)
7 110.6 (100)
8 0 (0)
9 104.3 (100)
10 0 (0)
11 0 (0)
12 0 (0)
13 158 (170)
14 0 (0)
15 177 (185)
20 0 (0)
21 197 (206)
A1 90 (90)
A2 0 (0)
A4 0 (0)
A5 0 (0)
A6 97 (90)
A7 0 (0)
A9 0 (0)
B1 98 (90)
B2 157 (170)
B3 111 (100)
B4 88 (90)
B5 170 (170)
B6 104 (100)
B7 0 (0)
B8 0 (0)
The manual says the voltages should be within 15% of what is listed on the page. To calculate a percentage, subtract the difference between the voltage you are seeing and the one listed in the manual. For example your first voltage is 98, so it is 8 volts higher than the 75-90 rage listed in the manual.
Now divide that difference by the number listed in the manual. We have a range of 75-90 in this case, but just use the top of the range for this case, 90 volts. 8/90=.088. Multiply that answer by 100 to get a percentage, 8.8%.
8.8% is less then 15%, so that voltage variation is well within range. You can do this for each measurement. With some practice you can do this math in your head pretty easily.
thnx doc . all good i wil go to the final test
