General Category => General Discussion => Topic started by: aragorn723 on February 05, 2015, 04:43:13 PM
Title: amplifier switch
Post by: aragorn723 on February 05, 2015, 04:43:13 PM
Hi,
Does anyone know of good amplifier switches?  What I'd like to do is use 1 set of speakers, and be able to switch between two different amplifiers.  One amplifier would be from the 2 channel setup, and the other would be a Onkyo HT receiver (so the speakers can be used for both music and HT).  Niles makes one called DPS-1, but is $90.  Are there other options that aren't as much $$?  (plus the box doesn't look that nice :-0
Dave
Title: Re: amplifier switch
Post by: Paul Birkeland on February 05, 2015, 06:19:06 PM
Which 2 channel amplifier are you wanting to use?  You may be able to drive the 2 channel amp with your Onkyo.
Post by: jake111 on February 05, 2015, 11:47:00 PM
Hey Dave,
I built one of these: http://www.audiokarma.org/forums/showthread.php?t=354119
Works great for switching between my HT amp and Quickie + Trends T-amp. Also nice for quick AB amp comparisons. Easy to make too.
Jess
Post by: jake111 on February 05, 2015, 11:51:49 PM
Oops, sorry about the up side down pics.
Post by: aragorn723 on February 06, 2015, 01:04:07 PM
Cool!  Looks like that would work.  What is in your version?  Looks like some kind of transformers?  What would be a good switch for this?  Parts express has this:
http://www.parts-express.com/4pdt-heavy-duty-toggle-switch--060-572
Is there another company that has a switch that would give a high quality signal transfer for audio?
Dave
Post by: jake111 on February 06, 2015, 02:23:34 PM
 Yeah that's the same switch I used. There might be ones out there with gold or silver contacts, I'm not sure.
 My HT amp kept shutting down because of the 6ohm main speakers I use. That thing you see in there is a wall mount volume control with multiple impedance settings. I set it so the HT amp sees 12ohms which keeps it from shutting down.
I don't need the volume control in there. I'd like rewire it so just the autoformer part is used, but that's a little over my head.
Post by: aragorn723 on February 06, 2015, 02:37:52 PM
Gotcha..  Is the switch an on-on function?  (2 position with no middle position).
Dave
Post by: jake111 on February 06, 2015, 04:22:22 PM
Yes, two position.
Post by: aragorn723 on February 08, 2015, 02:09:31 PM
Would it be possible to combine this and a battery box?  I have a bunch of boxes already:
amp
preamp
cd player
tuner
switcher for inputs
Would combining 3 12 volt batteries into a box and the 4pdt switch for switching amps cause any noise issues?  Would this be something that should have a metal wall between the two sides to cut down noise?  It would be nice to combine a potential 2 more boxes into one  8)
Dave
Post by: jake111 on February 08, 2015, 09:22:46 PM
 Ah yeah space saving. I doubt it would make any noise. You could run your speaker wires by the battery pack maybe even coiled around and listen for noise. :o
 I just made a little pack of 9v batteries (36v) moved them around in my switch box with music playing and not. Couldn't hear any noise. But probably not fair comparison.
Post by: Grainger49 on February 09, 2015, 04:14:00 AM
DC does not cause hum.  I would say that you should have no problem with the switch and batteries in the same box.
After all, the switch is for speakers, and that is the highest signal voltage level you have.  It is the least susceptible to noise pick up.
Post by: STURMJ on February 14, 2015, 02:51:57 PM
I've made A/B boxes using switches similar to the one you posted. I put them into a Hammond enclosures (di-cast aluminum). The switch on top, and ins and outputs on the sides. And give it a nice paint job before you put it all together.
Post by: aragorn723 on February 14, 2015, 03:45:56 PM
Sounds cool, do you have any pictures?
Post by: borism on February 21, 2015, 08:49:21 AM
Thanks to this forum topic and Jess (great Audiokarma link) I was able to address the issue of two amplifiers and one pair of speakers. I used an NKK 4PDT switch from Mouser, binding posts from Madisound and 14 g stranded wire. Works great!
Boris
Post by: jake111 on February 21, 2015, 03:15:01 PM
Nice work Boris. Happy to contribute.
Jess
Post by: aragorn723 on February 21, 2015, 05:18:13 PM
very nice, I like the beefy binding posts, gonna look for those when i build :)  Just got distracted with rebuilding a bike though, so the money may go there first  8)  Was it hard to figure out how to orient the switch?  (Does up/down matter??)  The thing that bugs me a little is the posts-there are so many..  If you pay $3 each, that's $36 just in posts!  (almost the cost of a chassis!)  Not that big of a deal i guess, but man!  (still cheaper than buying a niles switch).
Dave
Post by: Grainger49 on February 22, 2015, 01:42:36 AM
Very nice and tidy work.  That is quite a beefy switch.
Did you make the box as well?
Post by: borism on February 22, 2015, 03:31:26 AM
Dave I don't think up/down matters regarding the switch. What really helped me was the Audiokarma picture of the connections regarding amplifier A/B and speaker connections.
Grainger, I don't have the skills to build a box like this. I got it inexpensively on eBay.
Boris
Post by: Loggie on February 22, 2015, 03:58:24 AM
I have the same problem as the TS, two amps and one set of speakers.
Untill now I have been switching speaker cables when I wanted to listen to the other amp.
Having read about these 4PDT switches it seems like a great solution.....so thank you for starting a topic like this  :)
These switches come in on/on and on/off/on (or on/none/on) variations.....might be opting for the ones with an off position to avoid possible contact problems during switching.
On to Ebay now for some switch shopping :-)
Post by: aragorn723 on February 22, 2015, 04:56:18 AM
Boris
So the contacts on the top of the switch correspond to the upper switch position?  I want the upper position to be the "music" position, and lower would be HT.  Thanks,
Dave
Post by: borism on February 22, 2015, 05:02:00 AM
Dave, that's what I thought, that the up position of the switch I got corresponds to the upper contacts. However, it is the exact opposite. When the switch is up the lowest contacts are ON.
Boris
Post by: jake111 on February 22, 2015, 11:20:22 AM
I had to rewire mine because I just assumed the signal would go the direction the switch pointed. I like the switch moving horizontally so so it points to the amp I want to use.
Another nice thing about using this switch is you can avoid any amp power up noise by selecting the amp last.
Jess
Post by: Loggie on March 06, 2015, 06:01:48 AM
Inspired by this thread (because I was also having the problem of having one pair of speakers and two amps) I decided to make an amp-switch-box.
The switch is a sturdy looking switch from ALCO with an off position:
http://nl.mouser.com/ProductDetail/TE-Connectivity/A4TP15W04/?qs=%2fha2pyFadugHEG%2f%252b4xonx%2fAKU5HZw%252bS5JJ5sbaWD1yU%3d
Used 12 long binding posts and a generic aluminum casing.
The back looks a bit crowded and its a tight fit for the binding posts.
Its working really well.
It did take up a lot of solder though  :)
The final thing left to be done is to make some sort of identification on the switch.
Here are some pics:
Post by: borism on March 06, 2015, 02:51:52 PM
Nice work! I like the aluminum case.
Post by: Loggie on March 07, 2015, 02:13:58 AM
Thanks Boris,
I used a casing from Conrad:
https://www.conrad.nl/nl/proma-130044-universele-behuizing-165-x-110-x-80-aluminium-aluminium-522953.html
It wasn't too expensive and the size was perfect.
At first I wanted to make a nice wooden casing but decided to go for this one.
After looking at the pics I should have used shrink sleeves (not sure abaut the technical term) on the switch and binding posts to hide the solder :-)
