Bottlehead Kits => Crack => Topic started by: audiomaniac on February 08, 2015, 11:13:25 AM
Title: Testing LEDs?
Post by: audiomaniac on February 08, 2015, 11:13:25 AM
Is there a way to test an LED while building the Crack? When I was soldering the second LED to A8, it shifted a little and some solder flowed right up to the edge. I hope it's not damaged and was hoping I could confirm this somehow before proceeding.
Title: Re: Testing LEDs?
Post by: Paul Birkeland on February 08, 2015, 11:22:33 AM
Some meters can light them up on the diode check setting with the probes oriented in the correct direction.  You can try this by using your meter on the diode that isn't suspect.
Post by: audiomaniac on February 08, 2015, 11:30:26 AM
Sure enough! It lights, in fact they both do! Thanks very much!!
