Bottlehead Kits => Crack => Topic started by: Utopia on March 03, 2015, 06:14:35 AM
Title: Shorting RCA inputs
Post by: Utopia on March 03, 2015, 06:14:35 AM
My Crack buzzes with my Beyer T1 if I turn up to volume to perhaps 80 % of max (which I would never do listening to music). If I disconnect the interconnects from the RCA inputs I still get the exact same noise. However, if I short the RCA inputs, the amp is dead quiet even at 100 %.  I don't know quite how to interpret that. Is the source of the noise outside the amp? And do the RCA inputs pick up noise even when they disconnected?
Title: Re: Shorting RCA inputs
Post by: Paul Birkeland on March 03, 2015, 06:45:56 AM
That's kind of the end of the story.  If that's an insanely loud listening level, some noise is to be expected.  (Remember, signal to noise ratio is just that: a ratio.  If you crank up the signal to an unreasonable level, the noise will rise also)
What's the noise like with a source plugged in?
The results of this tell you that you have a quiet amp, and some noise in the environment.
