Bottlehead Kits => S.E.X. Kit => Topic started by: puhaha on March 08, 2015, 08:13:25 PM
I received the s.e.x 2.1 about 2 weeks ago and finished building on the last weekend.
I have put s.e.x 2.1 + c4s + impedance switch board + power line + badge (basically all except hat, I have a big head haha). Total building time is 5 + 4 + 4 hours (Fri, Sat and Sunday) excluding reading kit manuals a month ahead which I enjoyed a lot. Reading all 3 manuals inside out helped so much when I was building (sending manual earlier was very good idea in both building the kit and keeping me company while I'm waiting for the kits). I just use manuals to double check the part that I'm putting at that point.
As you can guess from my building time, I did not paint my bell and transformers as I like them without paint, but I finished the base with 2 coats of Danish natural oil over 3 days. So it looks just like the manual inside out. =) I might try vinyl cover tapes that other member shows in other thread.
Fortunately, I finished all of them without a major issue. Only thing I had issue was crinkling sound from tubes. I found a solution from the thread easily. It is getting better as time goes by (about 30 hours listening so far) and cleaning tube pins helped a lot. All of my resistors were +-1%, but voltages were -15% for most connections. I'm suspecting this is from tubes. It sounds good as of now so I'm not planning to cook tubes, I'm just going to listen as it better and better. Also, I'm just going to stack some 6dn7 tubes for future failures (so reasonable price haha)
After listening for my s.e.x amp for a week. I can say that this amp sounds so addicting. I have few amps, both tube and solid, that cost more than this amp and I like my S.E.X amp the most at this point. No direct comparison from me, I respected all other amp makers and I believe they have their own strength and weakness which are decided by my own personal taste.
I don't have "golden ears" but sensitive ears so I like my music low volume and still want the all the details. I can never slept with my headphone on, but I fell asleep on my chair with my s.e.x. amp without fatigue. And this sounds specially good with HE-500 on classical/orchestra genre. I always like this can but it did not have spacious sound and detail that I want. Usually, higher watt solid state amp that I have has spacious sound, but did not have enough resolutions. or if other amp has enough resolutions, then it loses the spacious sound. Now, I'm having very good experiences on both.
As I mention before, the main reason I got s.e.x. was I like orthodynamic headphones so much these days, I want some amp that put more watt into the can while it it keeps all sound qualities. But maybe I did not do enough research, it seems very from people to people now. Or I have a bias on my research now since I just want mainline now because Bottlehead is proudly representing the Mainline and it has better sound quality than s.e.x with all the upgrade that I have. I need some good excuses to my wife for justifying to get a mainline haha. Hopefully, a bigger sale in the future =)
I'm considering to upgrade 1.5uf and 0.1uf caps with reasonable priced cap if this helps to improve. I already upgraded a stepped attenuator that I got from ebay and I like it.
Please suggest me some upgrades if cost/performance ratio is good.
Thanks!!!
S.E.X. + HE500's are a very nice combination, i have the same setup myself. As you have said it has the power and detail to get the most out of them.
Enjoy!
Have you though about the choke mod? I liked the effect of it with my own Sex and its reasonably inexpensive. Other than that have a read through Mcandmars excellent ramblings \ build thread for some further ideas. You don't need to spend a lot on caps to see some nice gains over the stock ones saying that I did splash out on some Mundorf silver oils I agonised over buying them for some time but once fitted and with a little burn in I'm really pleased I did.
I am really enjoying my Sex with the my T1's. The Massdrop offer on the Fostex TH500RP is tempting as I have yet to scratch that itch but quiet a few mixed reviews on it.
http://bottlehead.com/smf/index.php?topic=5316.0
Enjoy!
YES! just HE-500 improvement alone, S.E.X is worth buying for me.
Thanks for the suggestions. I like that all mods that the suggested thread have to reduce noise floor.
I must implement the choke mod. It is very simple for both implementing and reverting, and cost effective. Only concern I have is I'm not sure how to make bases for those chokes. Did you buy a pre-made part or build one? I don't have a pile of scrap metals hanging around my house. :)
Mundorf M-CAP Supreme silver/gold/oil and silver/oil are expensive. I'm not sure those are worth or not. I will definitely do it if those caps make c4s level of improvement. I can try out Mundorf M-CAP Supreme version. But will regular M-CAP Supreme make as good as silver/gold/oil or silver/oil?
I'm also a card-carrying member of the HE-500 + S.E.X. 2.1+ club. It's been good enough to halt the upgrade train. For the record I've got the c4s and the impedance switch upgrades, also used Russian Teflon caps for the low-value ones and ESA ClarityCaps (less expensive than Mundorfs) for the slightly larger ones where Teflons aren't feasible for mere mortals.
Just got a balanced cable for my HE-500s and hooked it up to the speaker taps. Have to tell you guys - nothing else I did improved the noise floor this much. Before I had a tolerable but noticeable when turned way up beyond listening level white(ish, I know nothing is truly white) noise floor.
Switched to balanced mode via the speaker taps and it is 100% GONE, folks! The amp itself has no noise whatsoever, even with the pot maxed. I'd have done this ages ago if I had any idea.
I actually have a pair of chokes waiting for me to figure out a mounting solution, but with the noise completely eliminated I'm not sure I want to dig into this build again.
