Other Gear => Speakers => Topic started by: Strikkflypilot on June 07, 2015, 06:30:31 AM
These are Wellex E 6003 speakers.
The operating power is kind of strange "2.0 W 96dB/meter",
how shall it be understood?
Could the be run with a Bottlehead setup?
Anyone got an idea of this?
Those would be a fun set of speakers on Paramounts!
I would interpret the "2.0 W 96dB/meter" as 2 watts input produces 96dB sound level at 1 meter distance. To put it in more typical terms that would be 93dB/1W/1M. PB is correct, as usual, the Paramount 300B's would be the best match.
Geary
Fantastic guys. Thanks for the replies.
I am guessing I will order a Beepre/Paramount setup
at some point:)
galyons is correct. The 1966 DIN 45-500 standard (defining "high fidelity") specifies 96dB at 1 meter, at less than 2-3 percent THD in the midband. The power limits are the maximum for undistorted 2-second low frequency tone bursts. You can find it online.
Thanks Paul.
I learn something every day.
