Bottlehead Kits => Crack => Topic started by: Bungwu on June 20, 2015, 06:59:21 PM
Title: Speedball - I goofed, but what did I damage?
Post by: Bungwu on June 20, 2015, 06:59:21 PM
So I had the Crack assembled and working and began the speedball upgrade
I am new to DIY soldering and circuits and I failed to recognize that the 2N2222A and 2N2907A transistors were different despite the big red warnings in the manual. I thought it was referring to the resistors, not transistors.
Anyways, a quick run down of what I did:
I am going to go ahead and assume I fried the 2N2222As and possibly the 2N2907As, is there anything else I should check and/or be worried about?
Title: Re: Speedball - I goofed, but what did I damage?
Post by: Paul Birkeland on June 21, 2015, 06:51:55 AM
I would replace all of the transistors on all of the boards.
Generally a swap like this doesn't smoke the amp, so be prepared for additional diagnostics once everything is in its proper place.
Post by: Bungwu on June 21, 2015, 03:54:44 PM
Ok, I ordered the transistors.  I am guessing the bit of smoke was from a really bad solder point at 15 that I went back and fixed after my first set of problems.
Post by: Bungwu on June 25, 2015, 06:45:43 PM
Ok, I replaced all the transistors and the fuse and I have a different result now.
-left most LEDs off
-bottom right small board's LEDs are both off.
 I have no idea where to go from here.  Picture and voltages below.
Voltages
1   70
2   188
3   16
4   188
5   185
6   0
7   110
8   16
9   186
10   0
11   16
12   0
13   187
14   0
15   206
20   0
21   222
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2Fgzfb2CV.jpg%3F1&hash=8af50df054497f9c6eda5cd434930451e17f811c)
