Bottlehead Kits => S.E.X. Kit => Topic started by: ZacharyP on July 11, 2015, 11:41:40 AM
Title: Paralleling capacitors for the parafeed cap
Post by: ZacharyP on July 11, 2015, 11:41:40 AM
If I have 4 matched 1uf capacitors, same make and model, is there anything wrong with paralleling two and using a 2uf parafeed cap value?  Specifically, would this sound worse than simply using a 2uf capacitor?  I've read paralleling smaller values can actually be beneficial.
Thanks for anyone who reads, and any thoughts are appreciated!
Title: Re: Paralleling capacitors for the parafeed cap
Post by: Grainger49 on July 11, 2015, 02:58:39 PM
I had 4-0.22uF KK Teflon caps.  I intended to use them on my Eros.  I found that a single cap in each channel sounded better, more coherent, and they had no effect on the bass end.
Post by: ZacharyP on July 13, 2015, 12:31:04 PM
Hmm, might just have to try it out after fully acquanting myself with the amp.  Was going to use 1uf mundorf,zn.
