Bottlehead Kits => Legacy Kit Products => Quickie => Topic started by: sameerverma on August 18, 2015, 08:10:50 PM
I have a newly built Quickie 1.1
While the tubes that came in the box (Tungsram) are fine, what kind of tubes should I look for to replace these? Only 3S4?
Sameer
Or DL92 which is the European equivalent, and the MIL spec tubes are labelled VT-174 and CV820.
With a simple change of the heater circuit wiring you can also use 1S4/DL91 tubes. Identical tubes other then the heater voltage is 1.4volts vs 2.8volts.
