Bottlehead Kits => Eros Phono => Topic started by: jjvornov on February 14, 2016, 10:40:21 AM
I'm in the midst of my Eros build and have a problem at the Shunt regulator checkout stage.
First, only the LEDs on the A side of the board light.
On the wire connected to D6 I get 310 volts, on the D1 side I get 223.
I checked a few more voltages
KReg A is 4.4 V
KReg B is 22 V
IA is 313, 0A is 220
IB is 311, 0B is 313
At this point I've double checked the board connections and reflowed a few solder joints with no change. But with the connections it's hard to get to them all.
James
The 22V at Kreg B is something I have seen when an MPS4250A is installed where a TL431 should be.
Paul-
Definitely have the TL431's both on the board. Is it possible there's a bad solder connection on it? Can I reflow connections like that without disconnecting the board?
James
Your voltages could also indicate that there's basically no current flowing through the 12BH7. This could be from a flaky solder joint either on the board, or on the socket itself (are both halves of the 12BH7 glowing?).
Paul-
All good now. I took the board off and resoldered the tube pins and a few board connections. I think I found one jumper that was in and not soldered! So I reinstalled- got pretty good with the desoldering braid and got all 4 leds lighting and the right voltages on both sides.
Building a kit like this is fun, frustrating at times, but when you get it working, sublime
James
