Bottlehead Kits => Crack => Topic started by: Pumpkins10 on May 08, 2016, 02:08:31 PM
Title: Not sure what happened, but my amp suddenly sounds like poop
Post by: Pumpkins10 on May 08, 2016, 02:08:31 PM
Had my crack and speedball working with no big issues for a few months now, but all of a sudden the sound coming from the amp sounds the same as that phasey no bass sound you get when the jack isn't plugged in all the way. Tried wiggling it around that that, and nothing. Looking inside, the tabs are all making contact with the jack, so I'm kinda stumped.
I've double checked the solder points and that, so yea. Help would be appreciated  :D :D
Title: Re: Not sure what happened, but my amp suddenly sounds like poop
Post by: Paul Joppa on May 08, 2016, 05:02:32 PM
That's not really enough data to formulate a theory about the cause.
How about the resistance and voltage checks?
Post by: Nathan on May 09, 2016, 02:22:01 PM
Tube failure
Post by: Paul Birkeland on May 11, 2016, 07:34:23 AM
Tube failure
This doesn't generally happen overnight, and sets in so slowly that it can be hard to detect without comparing your current set against a fresh set.
A voltage check would be helpful.
