Bottlehead Kits => Kaiju Stereo 300B amp => Topic started by: fritzthecat on June 05, 2016, 12:43:44 AM
Hello
I just got some questionmarks regarding the wiring being used within the Kaiju kits...
I'm just curious about the wires used inside the Kaiju Kits, ways of improvement and general kit tuning recommendations.
Based on my experience with another Kit provider based in Canada I would say that the solid core wires provided with the Kaiju kit are rather thin - Is there any special reason for doing so and would it be critical to use thicker copper / silver plated copper or solid core silver wiring?
Are the provided wires maybe used because the wires inside the transformer and chokes are as well thin so that it just makes sense to take the same or are there any other reasons like balancing sound or even critical security reasons?
How about using silver plated stranded and solid core silver wire for the Kaiju build? Where should solid core be used in general and where stranded wiring?
I got two Kaiju Kits - the first one I am just about to finish using the provided wiring and parts - for the second one I am planning to use improved wiring with as much silver content as possible - does that make sense?
Regarding wire improvement and tuning possibilities: how about the PEC level adjustment pots? Any advice to replace these with something better?
Any general input regarding Kaiju kit tuning towards a even more high end approach?
I'm aware the the 10uF/630v polypropylene caps are a critical component for sound improvement as well - how about using Audio Note Copper Foil in oil caps or maybe VCaps here? Maybe someone would like to join me when I am going to order VCaps just to get some discount?
Does anyone have experience and general recomendation regarding Bottlehead kit tuning?
Any input regarding these questions would be very much appreciated.
Best regards and best wishes from Switzerland,
Chris
The wire provided with the Kaiju is much, much thicker than the minimum allowable wire that could be used in the Kaiju. We provide very premium teflon coated solid core wire that will not melt by the tip of your soldering iron (though we do provide some shielded twisted pair cable as well, and some heavier gauge solid core for the filament wiring).
A lot of these transformers have several different thicknesses of wire depending on the winding. The choice of copper size in a transformer is quite complicated, and may not dictate the minimum required wire thickness to be connected to said winding.
Stranded wiring should only be used in places where the wire is likely to move around a lot. In the Kaiju, I believe the only place we used stranded wire was for the input cabling, where we were simply opting for a higher quality shielded twisted pair cable, and it happened to be stranded.
This is a good idea.
There's always a more expensive pot out there somewhere. The improvements tend to be very expensive and very small.
The 10uF caps and 0.1uF coupling caps are quite important to the sonic signature of the amplifier. Since you have two amps, I would leave one stock, then put fancy caps in the other. I am not aware of any 10uF V-cap that has an adequate voltage rating for the Kaiju, though I believe there are some Mundorfs and Clarity caps that meet the requirements.
Thank you so much for your replies - makes many things much clearer...;-)
Best regards,
Chris
I just finished the assembly of my first Kaiju with stock parts - but as it got late yesterday I did not dare to turn it on - will do that tonite and perform the final adjustments in terms of hum balancing and remeasure voltages with inserted tubes and hope the magic smoke will stay inside the circuit.
The second Kaiju I will modify using more silver and other foil caps. Regarding the caps - does anyone have experience - I just ask because I am not quite sure what to use and on the other hand 10uF @ 630 Volts is not available from that many suppliers. Recommendations would be very much appreciated - general tuning recommendations as well as I have no experience with bottlehead kits so far.
I modified the chassis a little bit using some pinewood and a very work intensive Shellac finish (lots of very fine sanding, polishing and applying layer after layer - in this case about 30). If anyone is interested I build these for others or am available in case of questions any time.
Thanks to everybody and have a good start into the new week.
Chris
Nice work on the base, that would take time. Did you apply any finish to the transformer bell end?
Hi Chris. I can tell you what I did to my kaiju fwiw.
Moved RCA inputs to front of chassis. Used short runs of marigo copper wire with cotton insulation for input wiring
Marigo solder
Bypassed balance pots I also added a volume pot since I don't use a preamp
Moved speaker terminals to side and mounted on wooden chassis. Output wire is marigo copper
Used vampire speaker terminals and rcas
Used vcaps for input and mundorf silver oil for 10us
Eml mesh plate 300bs. These required some mods to bias correctly. You can read my thread on this for more info
DC regulator
Many will tell you different wire is bs but I have rewired other amps with the copper/cotton wire with good results.
Be prepared for a rocky ride with the caps. Break-in is annoying.
Hi Chris65
thank you...;o) I love working with woods - building my own speakers, furniture, guitars and stuff if time allows. For the transformer bell i usually take Metarex - see pic - with that you get a nice finish on almost any metal as long as they do not oxidate to much.
But I am thinking off building covers for the two chokes from aluminium and maybe apply some chrome to the transformer bells - but lets see... first I'll take an ear - did not find time up to now to turn the amp on for final adjustments - hope it won't blow - so far I am still using the 1,5 A fuse.
Hi drewh1
I got some experience regarding that - I used quite some VCaps in my AN Kits I built before (what a nightmare experience - compared to that I feel like sitting on cloud seven in heaven here) they are running for more than 200 hours now and still I hear them changing sound towards more sweetness and clarity and a very very transparent midrange - amazing. For these I used 1mm diameter silver solid core silver from Audio Note (which cost me almost more than the whole original kit - absolutely crazy but I just wanted to know what it brings) so they are hardwired completely and sound nice.
Marigo solder
DC regulator
Hi Drewh1
great - thank you - just a question regarding Marigo Wiring/ Marigo Copper - where do you get these from? Couldn't find any resources so far.
I have some PSVane Mesh Plate 300bs around - guess I have to mod as well to bias them correctly - never done before - I will read your thread and maybe get back to you with some questions.
VCaps for Input - I just don't have the manual around at the moment as I'm on a business trip so I don't know exactly which ones to be replaced - which value did you use and which voltage? As far as my experience goes there are only 300 & 600 V versions around and I only have experience with the CUTF 300 and 600 V versions I'm using on my AN Kits line hardwired line boards
Hi Chris. Talk to Ron at marigoaudio.com. I recommend his solder. My speaker designer swears by it. I used 600 v or greater caps, in this case the cutf .1 vcaps. I used mundorf for the 10uf.
I found some decent pre painted choke covers on eBay. Had to modify them but they look OK.
I am very happy with the sound of the meshplates. Mods are not difficult but best to build it and measure with standard tubes to see where things stand. Let me know if you have questions. And Paul at by is very helpful and responsive. Sounds like you had an adventure with AN. I considered their 300b kit for awhile but ended up with the Kaiju.
Hi Drewh1
adventure...? that would have been nice - it was and is a complete nightmare. Are you aware, that AN is not AN? The company Audio Note based in UK which is owned by Peter Qvortrup has nothing to do anymore with Audio Note Kits (ANK) based in Canada. Brian Smith from ANK (www.ankaudiokits.com) took over the kit business from AN (audionote.co.uk) about 11 years ago. 4 years ago Peter Qvortrup decided to separate the two businesses completely (and I guess he had good reasons to do so) and that Brian Smith is not anymore allowed to even use the name Audio Note with his products. I met Peter in March at the Mariott hotel in Zurich and he told me firsthand that he gets lots of complaints from unhappy ANK Kit buyers and that Brian is still sneaking the name Audio Note into his products whereever he can - but he actually is not even allowed to do so anymore!!! Okay, he changed the name of his company to ANK - but this still implies that there is at least some Audio Note inside his products - but this is not the case in terms of circuit designs anymore at all - only the older products are somehow based on original AN designs. Peter told me as well that ANK kits do not even sound good anymore as nowadays ANK is using own designs without any AN genes anymore. I built some older kits (L3 Phono, L4 Preamp, L4 DAC) which are still based on origninal Audio Note developments and I can say there really is Audio Note inside...;o) Stupid me ordered a kit1 using 300B output tubes that as well still is based on original AN design but the quality of what has been delivered is that low and the parts I got - I tell you, a pure nightmare (I just got a box full of bits and pieces - the tubes were missing, all coupling caps were missing, the output transformers etc. are crap and I could not get it to work up to now - I just lost about 5000 US Dollars as I had to buy lots of missing parts from Audio Note and they were not cheap. So really, I only can warn everybody: DO NOT BUY ANY KITS FROM ANK beside you are a fan of nightmares in terms of no support, no help and lousy parts quality. It is even difficult to unsolder stuff from their PCBs as the copper traces come off the boards immiediately when you have to reheat solder joints. I only can say: YOU TOOK THE RIGHT DECISION TO GO FOR BOTTLEHEAD...;o)
Hi Drewh1
thank you for the contact at Marigo - I'll contact him to get some solder and copper wire to check it out. I'd love to use my PSVane meshplats with the Kaiju but actually I do not have much experience with SET power amps so definitively I'll need some advice and help to get there. Thank you for the advice who I may ask...;o)
I'll check out your threads.
Thank you so much and have a nice day,
Chris
Well, I am not an expert but I looked at the specs for the Psvane Mesh Plate 300b. It looks like it is right in line with the standard 300b in terms of filament voltage (5v) and plate current (1.2A). it is likely you won't have to modify anything.
Too bad you had that experience with the ANK stuff. You will find plenty of help and information here. I have built 3 bottlehead kits and just sent a Tode off to my son for his birthday. I have had only good experiences with BH. Like any forum online, people do have their opinions but for the most part, it is a polite and helpful group.
I guess you are much more an expert than I am...;o) I'll try the PSVanes in the second Kaiju I am just about to start building. And I can only agree: Bottlehead is great - what you get here in terms of quick support and help is amazing - I am really happy with what I got from BH and I think the way the manuals are structured is exactly what a beginner needs - well, I am not a complete beginner but not so far away from that - I really want to learn as much as possible as our hobby is great and very satisfying and in the end when you are able to listen to what you built with your own hands it's just amazing when it sounds good.
What is so strage about ANK is that you do not find anything negative about them in the internet - but if you dig deeper you find lot's of people who went through the same nightmare.
Thank you for the kind comments! I don't know this for a fact, but we may sell a few more kits than ANK. That might have some bearing on how much info is on the web. Regarding the manuals - it is my opinion that if we condensed the instructions to a diagram like some have suggested to me we would lose 85-90% of our customers, including most electrical engineers. But my experience in this is limited by the fact that I have only been selling kits for 21 years.
I will defend one thing - traces will lift off of anyone's PC boards with too much heat, including ours. PC boards were never intended to be reworked. That has been their Achilles' heel since they were invented.
Marigo solder
DC regulator
Hi Drew
I just ordered 0.1uF cutf VCaps and the sillver oil Mundorf supremes - there are 10uF AN Copperfoils available as well I'll gibe them a try as well in the first kit later - Thel produces 0.1 uF and larger Silver Mica Caps - maybe these might do the input job as well. For all the wiring I got 0.5 and 1mm Solidcore silver wire and for the connection from the RCAs to the vol pots I got shielded neotech solidcore silver wiring. What do you think I could replace the volume pots with - the stock PEC I don't like that much - so the have to go - maybe TKD? Or what would you recommend. As I really want to go for a silver signal path (I'll replace all non silverleadouts of components through solid core silver like Kondo does - I had a chance to visit them in Japan so I saw how they do it - amazing! If I could afford massive silver foil caps I would even go for that option. I am very courious how the pimpee Kaiju will sound compared to the stock ones. I'll post some pictures as I go ahead... Thank you and have a great day, Chris
Those are trim pots for the inputs. I bypassed them completely. I added the goldpoint volume control as I use my kaiju without a preamp. I use goldpoint so that I can add a remote servo motor volume control. If you use a pre with some balance control you won't likely need them.
Can't wait to hear your report on the sound. those caps take forever to reach their potential though so it might be awhile. Some people break them in prior to installing.
I am surprised you are not using katatsuki 300bs!
Drew
Hi Drew
I actually never heard of katatsuki 300bs - do you have experience regarding these - just had a quick glance as I am sitting in the train travelling to work...
I am very curious to find out the difference between stock and "go crazy" Kaiju! I'll keep you up to date about the progress.
Actually I am using different preamps but none of them has a balance control (ANK L4 (pimped like crazy with lots of silver following advise from Peter Qvortrup) and a MBL sand preamp and soon a bee pre I am about to order within the next few days - what do you think about this one?
Got some more questions but have to jump out of the train - will be back soon...;o)
Thank you so much and have a great day,
Chris
snip....
Drew
I think they are Takatsuki TA-300B Damn fine sounding tubes. But I have only heard them in a series feed amplifier, not a parafeed.
Geary
I will see if I can afford them once I am finished with my "go crazy" Kaiju... At the moment I have a completely different problem as I just finished assembling my first build - stock version - checked everything - all connections should be fine (gonna recheck again) and then I should push the button and turn it on... This is my status for four days now! I just don't dare to, I am so f.... nervous and my heartbeat is pounding like crazy as if it wants to jump out of my chest - wuaaaah.... I am always so damn nervous - just hope I manage to do it tonite! And it is even getting worse as soon I am going to start my second build using pure silver solide core wiring and the caps mentionned above. I am just wondering if it would be possible to improve the stock resistors as well - what do you think? Should I give it a try? And if yes, what resistors to use in which place? Or would that just be crazy and useless? What do you think?
Another question: I'd like to have some chrome nickel steal top plates lasered by a friend - these are mirror quality and look absolutely amazing - is anyone out there interested in joining me so we could order some more? This would save quite some money and the top plates look great - maybe I can find a picture of something else he did for me. Will be back soon...;o)
Just attached two pics - on one you see the mirror quality chrome nickel steel covers my friend lasered for my home made power strips (they are not yet finished but soon they will) - looking forward to use them in my main system (as I have a slight hum problem and maybe with the right cables, stargrounding, graphite shielded cables etc I might get rid of it completely in the end - but this is something diffferent.
I attached the picture because I am planning is to have Kaiju top plates lasered as they look amazing - maybe someone whants to join me? Bottlehead does not provide the cad files to have them lasered - I already asked Joshua, but this no problem, or not a big thing - it is easyly possible to transfer the measurements from a existing top plate to the laser to do some more.
The other pic shows my Kaiju build number 1 - the stock version. I'm happy - all tuning parts I ordered including VCaps, Mundorfs and solid core silver wiring with teflon sheeting just got dispatched today so soon I can start building my custom version. Expect everything to arrive by friday...
Another question: What do you think - is it okay to turn the amp on (actually I am using a big Variac to slowly raise the voltage) while it is standing upright like shown? I just thought like this I can see the assembled parts and if the magic smoke is about to leave the circuit I am able to react to avoid the worst!
I am so damn nervous right now again - just feel a bit childish at the moment but I am really scared to proceed an do the final checks! I just don't want to screw it up in the last moment just before crossing the finish line - maybe someone can come over to hold my hand while turning up the Variac...;o)
So, let's do this NOW!
Thanky you guys for helping and advising me - you are great!
Geary
thanks for correcting my dyslexic spelling! All reviews of these tubes are excellent. I ended up with EML Mesh plate 300b's although still quite expensive, not nearly so as the Takatsuki's.
Don't know much about pre-amps, have never used one.
Chris,
Did you burn your house down? Or did your Kaiju work? :) :) :) :)
Jay
Hi Jay - I only burned the 1.5 A fuse so far - in the evening I gonna burn the resrt of the amp...;)
Hi Doc
I would never suggest to condense the manuals to just a diagram as the Manuals are really great and very well written - compliments to Joshua! I just thought it would be practical to have just an overview at the end of each chapter before test procedures to make it a bit easier to recheck all connections to be made before turning up variacs or pushing switches... Never ever condense these great manuals!
Only 21 years, actually I thought you got a bit more experience...;oD
Regarding traces coming of I have to say something as well: I had to resolder on yours as well as on many of the pcbs provided by DIYaudio - and never managed to overheat them in a way that traces lifted off from the board - but the ANK ones are really bad regarding this - they eben came off while just soldering components the first time - cannot tell why but maybe Imjust got boards from a faulty production batch - who knows and I don't care anymore as now I found my favourite tube kit suppliers.
Anyway, thanx for the great kits and the great forum and the chance to learn something here!
All the best,
Chris
Hi Drew
yesterday I got some parts for Kaiju number 2 and I am about to order a Bee Pre - but first I want to be on the safe side that at least one Kaiju is running smoothly - not there yet - I did not have the time to do some final checks and just turn it on - only variaced it up so far... Anyway - the Mundorfs arrived and I wonder how you got them in there they are about 4 to 5 mm longer than the space between the solder lugs - I thought of building a wooden support that allows as well to remove them again (no glue and no cableties) for them and just raise them in height so I can easily solder them. May I ask how your solution looks like? Or did you buy the EVO types which are much shorter while the diameter is higher? Would be great if you had some pics?
Chris
Hi Drew
I just made a picture quickly to show what I mean regarding caps size.
Another possibility to solve the space issue would be to have my own top plates lasered (already mentionned in another post) and move the solder lugs a little bit - a friend of mine - it is actually my neighbour living in the next house down the street - used to work in the lasering departement of a coffee machine company where they work a lot with chrome nickel steel in mirror quality and he still has the connections there and is able to draw the files needed for the lasering process - but this would really be a RR solution - but it would look very nice - if I go for an option like this it would be great to have a group together cause for one or two pieces it is not worth to start that laser.
What is the next project you are planning? What speakers do you actually use / own - you mentionned "your speaker developper" - I am just very curious as I am thinking about some open baffle designs - but I'm not so sure if this would work in my rooms (I have two listening rooms at the moment - maybe soon three as there are still some unused rooms in the house I live in).
And I am just thinking back and forth about ordering a bee pre as mentionned - but decided now that first the Kaijus have to be up and running. It would be great if you could share a bit of your experience regarding mods though I know you do not use a preamp at all.
Anyway - please tell me how you got the mundorfs fixed inside the Kaiju...;o)
Thank you so much, cheers
Chris
I merely removed the original cap and place the mundorf inline, hanging from it's connection wires. I didn't have a problem getting under it to solder the leads. I was careful to allow as much air space between the cap and the resistor as possible. In another post, I measured the temperature of this cap while running.
I am sure you could attach a support of some sort if you wanted but I have never had a problem with mounting caps this way. I do not move my equipment and it certainly doesn't get a lot of vibration.
I use Green Mountain speakers with my set up. Have used them for years and find they are the closest to electrostats in terms of imaging etc. Roy has been great over the years in terms of upgrading his products and has another secret upgrade in the works. they are a fabulous match with the Kaiju. I also just purchased a set of Blumenstein Orcas to use in a bedroom system with my Stereomour.
I do encourage you to check out Ron at Marigo. I use his wire for DIY interconnects and also for my speaker cables as it matches the wiring inside the speakers. He has a helix braided copper wire that is awesome for speaker cable although he has to tin the ends as the wire is so fine it will dissolve if overheated in the solder pot.
Really just enjoying listening so much right now, I don't feel the need for any other changes.
See pages 31, 35, 36, 38, 45, and 63.
If you have performed these checks, then you have turned your amplifier on before, several times.
Hi Paul
sure - I did - but me, being overcautious as usual always used a variac to slowly raise the input voltage...;o) But anyway - up to now I just pushed the button until installing the DC Filament upgrade - to check if everything works I'll use the variac again.
Talking about tuning options - would it be apropriate to replace the big white wirewound (?) resistors used inside the stock Kaiju by let's say Mundorf MResist wirewound types of same value or wouldn't that make any sense at all?
Hi Drew
thank you so much for the picture - great...;o) I'll try it with some sort of support - got something in mind I'll work on - I mean for a perfectionism freak like me there is no other option anyway. I installed the DC Filament upgrade last night - will check out tonite - it was actually quite difficult to rewire everything as I took the word "attach" very serious - so I had to use brute force to get it done - hope I did not damage resistors by overheating them etc. - I attached a picture for you. The VCaps and Mundorfs I'll use in my next Kaiju where I go for complete solid core silver wires with teflon sheating - let's see...;o)
Have a great start into the new week and all the best from Switzerland,
Chris
Btw. Where are you in switzerland? I used to visit Geneva and laussane quite frequently. Even sailed on lake Geneva
It's the other large lake - lake constance - I live opposite Friedrichshafen in Salmsach, just next village from Romanshorn, where the ferry (Romanshorn-Friedrichshafen) harbour is located - actually when you take that ferry you are paasing about 100 meters from my house...;)
For the 120 Ohm resistors, the Parallel Feed output topology that we use will tend to reduce the impact of power supply modifications. Having said that, they can still be slightly audible.
There are also the big beefy 1K cathode bias resistors, but the 100uF cap across each one will be far more audible.
Chris - I was planning on leaving well enough alone and now you bring this up :). I don't see the mundorf m-resist in 120 ohm. Do they make them? I think if I am going to change out the 100uf caps (probably using mundorf Evo) I might as well do the resistors as well while I am in there.
I'm sorry that I brought this up. You are right, the Mresists are not available @120R - I gonna ask Nick from HifiCollective for advice - keep you up to date what is going on @ the resistor front.
Just to be sure: You would replace the 220uF/250V Cap through a Mundorf EVO equivalant? Is it okay to use a foil type there? I thought it has to be a electrolytic type?
The 1KOhm 25Watt resistors should be replaced then as well, don't they?
I'll do some research regarding the 120R 10W and the 1KOhm 25 W types - I think Ohmite could be a decent replacement? What do you think?
Anyway, I'll let you know, what Nick comes up with - maybe Chris Johnson from Partsconnexion has an Idea as well.
Just to be on the safe side: They all have to be wirewounds - right? Or could one go for something like Path Audio as well (I know they offer special values made to customer specs - but I don't know if these are decent for the Kaiju).
BTW - I just ordered a Bee Pre yesterday and I want to really use the best parts available - gonna ask the two Botthead Pauls for advice which measurements have the biggest impact - my goal would be to create kind of a tuning/upgrade guide which steps have to be taken in which order to achieve the best results - let's see, what one can come up with.
BTW 2 - Where do you order your tubes?
I would be interested in how you determine this.
Uh, I'm sorry - I forgot a word - I wanted to write "the best looking parts available" so I am at least able to post pictures of tidy builds...
Hi Chris,
I miss-typed - I would look at replacing the 1k ohm wirewound resistor and 100 uf capacitor on the output tube circuit (pg. 44 in manual). Ohmite has its AudioGold series, probably Mundorf for the capacitor. No plans to mess with the power supply circuit at this time. If you want EML tubes, I would go direct to EML. My advice is stay away from TubesUSA as I had a bad experience ordering through them. It wouldn't make sense for you to use them from Europe anyway. So far, I am very pleased with the EML Meshplate - very transparent and musical tube. At some point, I would like to try the EML 2a3 Mesh in my stereomour.
Doc - I really appreciate Bottlehead because your products give me a platform to modify so I learn more about electronics. spending most of my life as a professional musician, I tend to trust my ears when making mods although mods do seem to have a cumulative effect. I am also sure I have spent money on audio BS but better to do it buying parts than buying one expensive amplifier after the other. It is a great hobby! Thanks for creating these products.
drew.
That's good. It's all about what sounds best - to you! And that is why, no matter what some salesman may tell you about the perfection of his product, there really is no universal best in any of this stuff. For me, a combination of reliability, continued availability over a long period of time and a sound I am very satisfied with is what makes a part the "best".
Absolutely agree - I got two Kaijus - one already finished just using the parts you provided with the kit - the other one I am just about to build and that's how I want to find out what is "my personal best" or the best to my ears: I thought about replacing single parts and then compare what's changed (guess I have to leave especially the foil caps for quite a while as they have to break in) - so I think I'm going to have quite some fun for the next - let's say - few years to find out - maybe I never will - at least I'll try.
Can you use oil caps for the 0.1uF coupling caps if the voltage rating is correct?
Sure. About the only cap I can think of that you wouldn't want to use is a motor start cap.
A few years ago, there were several reports of Jensen oil caps leaking current, especially the copper foil+oil ones; these caps were also sold as Angela and Audio Note according to some reports. Also some Duelands were reported to leak oil; those were said to have been made by Jensen. Some posters said that oil caps need to be sealed (e.g. the old Vitamin Q caps), more to prevent corrosion and electrical leakage than to prevent oil from escaping. Reportedly, Jensen has fixed some or all of their own problems in current production, but of course a lot of the older ones are still around in inventory or on ebay.
I can't vouch for the accuracy of these reports, but it's an issue. You might do a little googling some fine afternoon when you have a few hours to spare ... :^)
