Bottlehead Kits => Crack => Topic started by: bmilcs on September 18, 2016, 02:59:12 PM
Title: Crack Resistance Check before Voltage Check
Post by: bmilcs on September 18, 2016, 02:59:12 PM
I just want to confirm that I'm doing this correctly:
https://www.amazon.com/gp/product/B000X5TSUA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Firstly, Here is my ohm reader.
The only way I am getting correct measurements that make sense is with 200K dial locked in. I assumed the 20k would be what I wanted and should show 2.9k but nay. The only way I could get the readings that were specified in the Crack manual were on the 200k setting.
I've read the resistance check page a dozen times. I finally came to understand that I was supposed to:
1) Connect the black alligator clip to 12 on the transformer.
2) Somehow connect 12 and the ground, a spare alligator clip was recommended.
I used the spare wire from the kit and made little hooks at the end to make the connection and do the tests.
I was receiving 2.9 where I was supposed to receive 2.9.
My RCA jacks came out to 107.9 and 108.0 so that seems good yes?
0's came up as 0's.
* would steadily climb. They generally were around 30 and kept going up the longer I stayed on them.
Am I safe to continue?
Title: Re: Crack Resistance Check before Voltage Check
Post by: fullheadofnothing on September 18, 2016, 03:03:57 PM
DO NOT use terminal 12 on the transformer. Use terminal 12.
Every connection to the transformer is explicitly called out as being on the transformer. The resistance instructions do not use the word transformer, and therefore you should not use the transformer terminal.
Post by: bmilcs on September 18, 2016, 03:56:43 PM
Thank you. It's been an exhausting weekend and running on very little sleep. This is exactly why I waited to test it for real and posted here first.
Post by: Doc B. on September 18, 2016, 04:01:57 PM
Slow down. Wearing your self out building an amp and test firing it is a recipe for disaster. Take a break from it and come back to it when you feel fresh. Recheck all your work, then take the resistance measurements.
Post by: bmilcs on September 18, 2016, 04:18:55 PM
I was in bed when I typed all this out :D. Beat ya to it. I triple checked all my solder joints before going to resistance check. I am very confident in my soldering skills and finished product; I just didn't understand the instructions for resistance checking. I just got up to brush my teeth and set my DMM to 200k, with the black clamped to terminal 12 (not the transistor) and a temporary wire running from t12 to ground. I get exactly the numbers specified in the manual.
For the * values, they start at roughly 22 and climb from there. The main thing I'm looking for is 0 resistance where there shouldn't be. Right?
It all checks out. If I were to make one change to the manual so far, it would be the resistance check part. I found it a little confusing. Pictures do wonders.
Post by: bmilcs on September 18, 2016, 04:22:57 PM
After rereading this, I see where it may seem as though I'm haphazardly throwing this thing together. I assure you.. I'm not :).
I read each instruction 5 times and checked each picture over and over before soldering in place.
Post by: fullheadofnothing on September 18, 2016, 04:36:44 PM
Terminal.
Twelve.
Is.
Ground.
That is why you attach the black probe there.
DO NOT ADD ANY WIRES.
They are not needed.
They are not mentioned IN ANY WAY in the manual.
They will create a ground loop that will create issues. Read the instructions and follow them.
Post by: bmilcs on September 19, 2016, 05:11:16 AM
1) Thank you for clearing this up. I completely understand at this point.
2) Let me explain why I misunderstood after reading this paragraph over a dozen times and asking my wife what she thought as well.
*Again, I am clearly a layman and am new to this whole process. I may be stupid but I am not dumb and that is why I made sure before moving on to check with the forums.*
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2F3Lc4QXX.png&hash=c0384d3b45e47bda1772d73b70c07f9be4ca70e4)
Quote
Attach the negative lead (typically black) of a volt-ohm meter to terminal 12.  (I was blatantly wrong regarding the transistor 12 vs terminal 12)
BUT...
Use of a clip lead to connect the black test lead to the ground buss will free one hand, making testing much easier and safer.
With my limited understanding, "connect the black test lead", which I clipped to Terminal 12 due to the first sentence, "to the ground buss", I remembered and checked back in the manual to the ground nut/clip/thingy in the beginning stages of the manual.  There weren't any photos included in this section and so these were my assumptions.
So, in my clearly moronic and uneducated brain, I thought okay: I don't have any extra alligator clips. I do have this excess wire and that should create a temporary connection for the purpose of this test. I didn't understand why I would do this but I'm not questioning it. I cut 7mm off each end of the excess wire and simply hooked it around the ground and T12 as you explained earlier. Then, I went about the DMM test and afterwards removed the wire from the project.
I'm sorry for aggravating you. I am not an electrician. This is a beginners kit and I didn't think having questions like this would be met with hostility. Then again, it's hard to read emotion and attitude with just text.
Post by: bmilcs on September 19, 2016, 05:19:15 AM
My RCA jacks differ by .2 ohm. Will this be an issue? One is 108.4 and the other is 108.6.
Aside from this, my ohm checks continue to be spot on. I will do my voltage checks after work
Post by: Paul Birkeland on September 19, 2016, 05:32:43 AM
This will not cause any problems.  It's normal to see one at 90K and the other at 110K.
Post by: fullheadofnothing on September 19, 2016, 05:39:57 AM
There is no hostility here. You just seem to be having trouble comprehending, so I was attempting to explain away any possible doubt. The ground buss is the whole series of ground wires. The safety ground is a point on the ground buss, but it is not the be-all end-all of the ground buss.
The first sentence is an instruction, attach the lead to 12.
The second sentence is an explanation of why you would want to use a clip lead. It is a recommendation of best form for following the instruction provided in the previous sentence.
Post by: bmilcs on September 19, 2016, 06:41:07 AM
Great to hear.
With the * indicators, steadily increasing values is what I'm looking for right?
Post by: bmilcs on September 19, 2016, 06:44:39 AM
I do appreciate clearing it up. Sorry for being quick tempered and explaining.
One last question guys, my large GE tube has very dirty metal legs on it and the metal seems oxidized on the outside. I didn't realize it until I removed it from the glow test. Is this normal?
Post by: Paul Birkeland on September 19, 2016, 06:47:28 AM
You're looking for something that isn't close to 0.
Post by: Paul Birkeland on September 19, 2016, 06:48:05 AM
6080's haven't been made for a long time.  The metal is old, and will show some age.  This is normal.
Post by: bmilcs on September 19, 2016, 07:24:36 AM
Alrighty cool. Thanks again.
Wish me luck in not dying today :D
Post by: bmilcs on September 19, 2016, 10:14:20 AM
Drum roll please...
Voltage Check Results:
1. 84
2. 174
3. 0
4. 174
5. 81
6. 0
7. 109
8. 0
9. 109
10. 0
Both LED's are lighting up.
Small tube is glowing at top in 2 locations
Big tube is glowing on both sides.
Do we have lift off :D
Post by: Doc B. on September 19, 2016, 11:12:15 AM
Sounds like you are ready to listen to some music. Well done.
Post by: bmilcs on September 19, 2016, 11:37:00 AM
Figures but the RCA to RCA wire I bought for my incoming Modi 2U doesn't work with my 2i2.
So, I hooked it up to my TV and turned on the music channels.
To say I was blown away... is an understatement. I just had goosebumps for 45 minutes LISTENING TO ACE A BASE, PAULA ABDUL and JUSTIN BEIBER. I mean... I can get down to some modern music but I grew up on 90's alternative and classic rock.
My nipples are still hard as we speak HAHAHAHA
Honestly, it transported me to one of those adolescent moments some 15 years ago: smoking a joint with my friends and getting absorbed into music.  It was like being transported to a Tool concert that I went to in 2003 that was like a religious experience.
Dude.
DUUUUDE.
Post by: adeep42 on September 19, 2016, 12:48:42 PM
Although my music tastes might be a tad different than yours (although I do listen to quite a lot of classic rock and some very contemporary), your description of the Crack amp is on the money. If you go the Speedball route, you're in for another blown away moment.
A
Post by: bmilcs on September 19, 2016, 01:05:53 PM
A
I've thought about it since listening and I'm scared to change this at all ! :D
I'm going to enjoy the stock Crack experience for at least a month before upgrading.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2F44Hxxde.jpg&hash=770eed103f6a8642c7e6882431aa253247417547)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FCOTiDNb.jpg&hash=4fca38a6754c5e4e397bb475d0826a34b0eaea84)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FuyLf43O.jpg&hash=f89432b9dbe71061fe23785fa19ae2572e2ed62f)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2F0jdzp50.jpg&hash=20472535bf82e19b444b61910efa25a033da8060)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2Fnkzogl7.jpg&hash=3586e5ad5b12def093f460dfa6e52f637b2b7451)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FPNv3Ro2.jpg&hash=1e00f34a81fce8e8b576227f8cfde54e56175b74)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FpTZbxxq.jpg&hash=4990e0a1fd56bb5410efe8e866e4da24fb3da4da)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FAr60kDp.jpg&hash=a1d39a2bbad8c637ed428f867fe8bb426209aae5)
Post by: adeep42 on September 19, 2016, 01:24:37 PM
I listened about a month before I did the Speedball upgrade, however I did order the Speedball with the Crack so I really had to do it. Dude, it was worth it.
Post by: bmilcs on September 20, 2016, 12:29:35 AM
A
My choices were very limited for testing because it was hooked up to my cable box :X. You won't find any of those musicians on my PC, I promise you.
The Crack is magic.
Post by: bmilcs on September 20, 2016, 12:30:37 AM
I bought them together as well. I was expecting to be let down by the solo Crack.
Holy cow.
Post by: bmilcs on September 20, 2016, 12:41:49 AM
Aside from the resistance check confusion, the instructions for the build were really fantastic.
Very easy to follow. My A.D.D. did not stop me from building this without a single issue throughout the whole process; from soldering, to resistance, voltage and then listening. :D
Question --- I was at Home Depot the other day to pick up alligator clips for my DMM and picked up Gorilla Glue on the way out. It's the multipurpose kind... and not the wood glue.
Is this really not the right way to construct the case?
I saw a post saying that it expands a lot, but I really want to get this tape off the wood.
Post by: Deluk on September 20, 2016, 01:32:24 AM
Build is very neat, well done. Standard white wood glue is fine. As you are gluing two end grains together at each corner that helps with the strength of the joint. Try not to get any seepage onto the outside of the case as this tends to seal the grain and will make for a patchy finish if you use stain. It's water based so can be wiped off with a damp cloth. A light sanding first is a good idea anyway and you may need to do that to remove tape marks.
Post by: bmilcs on September 20, 2016, 04:58:57 AM
Is it weird that I want to glue them together and then sand it down? I was hoping for a semi-rounded edge finish.
Post by: JamieMcC on September 20, 2016, 05:25:46 AM
Your multi purpose Gorilla Glue will be fine it has the advantage of filling small gaps as it will foam during cure it cleans off easily and will also take a stain.
I glued up my Eros enclosure this today and it took no more than five minutes (I've made a few now). My tip for you would be to do it on a flat surface and be sure to glue it up on some plastic sheeting a cut up bin liner works well and this way the enclosure wont stick to your table.
Here are a few pics of the process I used the alloy top to check for fit and squarness.
Post by: bmilcs on September 20, 2016, 05:44:57 AM
Very clever. I like the way you taped up the entire edge, preventing any glue from seeping through.
Will it be okay to do staining and whatnot after glueing it all together?
I plan on creating the rustic, reclaimed look. I love that old, almost charred look.
Exactly what kind of wood is this? Is it that pressboard stuff? If I do sand it, will it dissipate quickly or will I be okay?
Post by: Doc B. on September 20, 2016, 05:49:20 AM
PU glue will stain your skin, so be careful to clean it off your fingers. I prefer Titebond regular or premium (not polyurethane) wood glue. It's maybe not as strong, but seems strong enough and doesn't blow out of the seams like the urethane glue does. If you do use the urethane glue be sure to dampen the wood with a damp rag before you apply the glue. It will make the joint stronger. And do be sure to wipe any ooze off the outside with a damp rag.
The wood is not "that pressboard stuff". The bases are custom milled for us out of locally harvested alder by Harmonic Design Works of Bellingham, WA.
Post by: JamieMcC on September 20, 2016, 07:12:00 AM
Yes as Doc says don’t get any of the polyurethane glue (gorilla glue is just a well-known brand name for it) on your fingers it can/will stain them a black colour which will not wash off!. The PU glue is moisture curing if you’re in a hot dry place or need to speed the cure up a wipe over the joint to be glued with a moist rag will speed the cure up and is a handy trick.
You also only need a very very *FINE* smear of glue on each joints surface otherwise it can/will get messy quick. On the plus side it is strong and any excess can easily be cleaned up with sand paper or a sharp chisel after its cured. Covering the exterior side completely with masking -tape goes a long way towards getting tight joints and not letting any excess glue escape onto the exterior of your enclosure. Don’t forget to take the alloy top off the enclosure after you have used it to check for square-ness or it might get stuck to the wooden enclosure.
I use the PU glue quiet a bit as it will stick to almost anything.
Post by: bmilcs on September 21, 2016, 01:16:01 AM
Right on. Thanks for the tips guys.
I ended up moving forward with Gorilla PU Glue last night using tape to cover all visible edges. It came out great.
I made sure the bottom was perfectly aligned while sitting down to dry. Sadly, not all 4 pieces of wood are equal heights so I'm going to have to sand it down a bit so that it looks flush.
What sandpaper is recommended for this project? I thought I read 180 and then 220 but I'm not sure. Thanks :P
Also, should I sand it by hand?
