Bottlehead Kits => Crack => Topic started by: potable on September 21, 2016, 05:06:04 AM
Hey guys, I'm really enjoying putting my crack together, but I've hit a wall and I need some help.
Let me start by mentioning a couple mistakes that might be relevant. While doing voltage checks, I sparked on the 13th terminal, might have impacted that 12+13th capacitor. Also, I originally had the 6080 socket oriented incorrectly :-[, and had the crack on in that incorrect configuration for voltage checks.
After re-orienting the socket, all the checks cleared and the crack worked, but only in the left output. For troubleshooting, I reheated the solder to the headphone jack and when I retested it the crack had no audio, the 12AU7 tube and LED's would not light. Another voltage check showed me I had a number of terminals off:
Terminal / Actual / Suggested:
1 / 141.4 / 75-90
5 / 140.8 / 75-90
7 / 141 / 100
9 / 140 / 100
A1 / 141 / 90
A6 / 141 / 90
B1 / 141 / 90
B3 / 140 / 100
B4 / 141 / 90
B6 / 140 / 100
These two terminals arn't too far off, but they did drop in voltage:
B2 / 158.6 / 170
B5 / 158 / 170
The other terminals are within threshold.
I have some more tubes coming in, as it seems I might have damaged these with the bad orientation. However I definitely want to see if there is anything I should try or check before I try swapping tubes.
Thanks for taking the time to read this!
(Edit: just realized my suggested and actual numbers were switched, fixed)
Does your 12AU7 glow when the amp is on?
Neither tube is drawing any current in your amplifier. In the Crack, the twisted pair of wires leaving power transformer terminals 4 and 5 is responsible for heating both the tubes, and bad solder joints on this pair of wires will cause the exact issue you're having.
12AU7 was not lighting. I re-heated the twisted pair line, to both sockets, and no change. Unrelated, I had wondered why each tube needed a dc and ac line, so its cool to know the function.
Good news is the other tubes I was planning on rolling arrived and when I swapped them in the crack otl works. Voltages are good, and I"m listening to it now. I'm VERY stoked.
I had a few hiccups along the way and this forum was a great resource for getting ideas on what might be wrong. That other user that miss-oriented the amp tube is what clued me on to what I did wrong. A bit embarrassing but hey, I still got a sweet amp in the end.
Thanks for making and supporting this great product!
