Bottlehead Kits => Crack => Topic started by: tsaG on September 27, 2016, 01:52:44 AM
Title: Transformer for the crack
Post by: tsaG on September 27, 2016, 01:52:44 AM
Hi,
I plan on buying the kit including the speedball and first wanted to have a closer look at the schematics.I do have some questions about the transformer used in the crack. What is the actual output Voltage and current?
I had a look into the manual and the tubes are feed with 170V DC. The Transformer supplies 150V AC (as it is mentioned on the label). Which is around 150*root(2) = 212V DC
So there should be a drop voltage of around 42V in the power supply ( 212V - 170V = 42V). We do have a combined resistance of 540 Ohms in the power supply which should result in a current of 77mA! (U/R=I -> 43/540= 0,077A). Which is out of spec by a decade.
And also, what does "doubler" mean? Are the two coils connected in series? If so, it is not in the schematics.The pictures look more like a parallel connection.
regards
Title: Re: Transformer for the crack
Post by: fullheadofnothing on September 27, 2016, 04:34:37 AM
So... just to be clear here, you are requesting free technical support for a manual you stole...?
Post by: adeep42 on September 27, 2016, 05:41:33 AM
Nice!!!!!!!!Great comment Josh.
Post by: tsaG on September 28, 2016, 12:07:18 AM
We'll....I just googled for the manual to get some information about the amp like I do for almost every piece of equipment I own.
There are several headphone amps and people are acting like "black boxes" with magic in it. I built several solid state and tube amps, the tube is not a "magical" thing for me. The manual I have is revised at December 17th of 2013, this manual could be older and this has maybe been already corrected (?).
Don't get me wrong, I really like your kit but I just like to know what I get before I click the buy button.
regards
Post by: Doc B. on September 28, 2016, 04:18:02 AM
The voltage and current output of the transformer are correct for the circuit we have designed. The only reason I can think of for the particular line of questioning is to gather enough information to try to find a different transformer so you don't have to buy the kit. The schematic you are using was obtained illegally, we have never given anyone permission the post it to the internet. I must admit I chuckle to myself every time someone chastises us for not giving away our intellectual property, says it's nothing special, and that they don't understand how it works - usually all in the same sentence.
All that said, if you order a kit from us we would be happy to answer the questions you have asked. We're known for very good customer service. All you have to do is become a customer to experience it.
