Bottlehead Kits => Crack => Topic started by: ideal.hat on November 16, 2016, 10:56:20 AM
Title: Speedball Upgrade. 2 LEDs are off = D1 Diode was not functional. [resolved]
Post by: ideal.hat on November 16, 2016, 10:56:20 AM
Hello there.
I was able to build the crack without problems and all voltage readings were fine and the amp worked like it should.
Tonight I started on the Speedball upgrade and I am experiencing some difficulties.
This is the current status:
Crack: 1U  measures 0V (It used to measure 76V before I started on the speedball upgrade)
Speedball: OA measures 0V
Speedball: LED D1 on A site does not turn on. Other 3 LEDs are glowing fine.
Crack: LED that is connected between Center terminal on socket A and to A8 Does not turn on. The second LED glows fine.
This is what I have done so far,
Resoldered both MJE350's
Resoldered 1U
Resoldered Center Terminal on socket A
Resoldered A8
Double checked that PN2907A are seated correctly (See attached pictures)
I would appreciate any assistance I get with this.
Best Regards,
Gudmundur
Title: Re: Speedball Upgrade. 2 LEDs are off
Post by: ideal.hat on November 17, 2016, 09:15:31 AM
I still cannot figure this out and the weekend is around the corner.
Hope someone can help me with this so I can hook it up to me new 2Qute DAC :)
Thanks in advance.
Post by: Doc B. on November 17, 2016, 09:56:07 AM
With power off, amp unplugged, check the solder pads that the transistors are mounted to (both MJE350 and 2N2907) to make sure that there are no solder bridges between transistor leads. Measure resistance across the LED that doesn't light to make sure that it or the 2N2907 are not shorted. If shorted you will see a very low reading, like 50 ohms or less. Normally that will measure either infinity or over 400 ohms, depending upon the orientation of the test leads with the LED leads. Also make sure your connections from the PC board to the rest of the circuit are good.
Post by: ideal.hat on November 17, 2016, 10:57:19 AM
Thanks Doc.
I will follow your advice tomorrow and report back.
Post by: Paul Birkeland on November 18, 2016, 06:44:46 AM
Also, check the DC resistance (with the amp off) between pins A4/5 and pin 6.  If those two are touching, or have started touching since the Speedball was installed, then you'll get 0V where you see it.
Do not do anything to the LED on the tube socket that isn't lighting.  That isn't related.  If it was bad, you would be seeing very high voltage at T1.
Do reheat the center leg of the MJE-350 transistor.  Give it a good 5-10 seconds of heat to be sure the solder is flowing properly.
I would also suggest taking a photo of the bottom of the PC board and posting it here.
Post by: ideal.hat on November 18, 2016, 01:33:15 PM
Hello both.
I have been doing my best in following your suggestion and the problem is still unresolved. I have updated new hi-res pictures, see pictures at the fooder of this post.
Doc: I have made sure that there are no bridges between transistor leads, both on MJE350's and 2N2907's.
The resistance across the LED (D1 A side) is infinity.
There rest of the connection on the PC board look fine to my untrained eye :)
Paul: Pin A4/5 and 6 are not touching.
"Do not do anything to the LED on the tube socket that isn't lighting.  That isn't related.  If it was bad, you would be seeing very high voltage at T1. "
I have not been able to locate T1. Could you please explain further?
I have reheated the center leg of MJE-350 and heated it for 10 sec.
I have spent good time on taking as sharp photos I can in my light conditions. Please see pictures below.
For some reason I was not able to attach these pictures to this post. They might have been too big (~8mb each) in case there is a size limit, so I have uploaded them to flickr.
https://www.flickr.com/photos/28459414@N08/30732455630/in/dateposted-public/ (https://www.flickr.com/photos/28459414@N08/30732455630/in/dateposted-public/)
https://www.flickr.com/photos/28459414@N08/30292764733/in/dateposted-public/ (https://www.flickr.com/photos/28459414@N08/30292764733/in/dateposted-public/)
https://www.flickr.com/photos/28459414@N08/30732452860/in/dateposted-public/ (https://www.flickr.com/photos/28459414@N08/30732452860/in/dateposted-public/)
https://www.flickr.com/photos/28459414@N08/30292761953/in/dateposted-public/ (https://www.flickr.com/photos/28459414@N08/30292761953/in/dateposted-public/)
Post by: Deluk on November 20, 2016, 02:11:05 AM
 Note:I haven't done my Speedball upgrade yet, I have the dual small board version of the kit. After looking at your Flickr pictures, am I missing some thing here or are you in fact missing something there? Procedure looks to be that you build up the conversion boards first. Dual or single "small" board and the large board with the heat sinks. No sign of the large board in your pictures. First job when fitting is to start with the "Demolition" as the manual calls it. Although you appear to have removed the 2 small resistors, the big of 22.1k ones are still in place. These have to be removed before fitting the new boards. Even as it stands I can't see a reason why you are firing it up and measuring voltages at this point. Noting that I'm a novice builder, my crack worked perfectly from the start and continues to do so. As always, reading the manual again might be informative.
Post by: ideal.hat on November 20, 2016, 09:18:38 PM
I am just following the manual. Before I install the bigger PCB, I should do some measurements first. To me this also sounds reasonable, since it should simplify the troubleshooting process with fewer components connected.
I have already removed the 22.1KΩ resistors from terminal 1U/2U and 4U/5U. That should be clear on the pictures I have places on the post.
On page 19 in the manual, its time to make some measurements before moving forward. to verify the PCB has been correctly installed.
If the small PCB measures OK I should move on to install the large PCB, starting from page 21.
Post by: Deluk on November 21, 2016, 01:51:24 AM
I think the Speedball manual must have been revised, perhaps then when the 2 small boards were replaced by one. Yes the 2 small resistors are the 22.1 k ones, sorry my mistake, and the big white ones are the 3k ones which should also be removed as part of the demolition. Removing these is on page 18 of my manual. Installation starts on page 19 and goes on to page 25. There is no testing done on these pages. Page 26 says "You're done building!" and after some notes on the next page (26) and a reference picture of the completed chassis (27) the next two pages (28) and into p29 runs through the voltage checks.
Unless there are reasons not to do so, I will follow my instructions without doing any testing. Maybe the BH team had reasons to change/add this bit of interim testing. I don't know, but a comment from them would be interesting.
Post by: ideal.hat on November 25, 2016, 01:07:01 AM
I am still struggling with this. And nothing has changed.. :(
I really hope someone can help me with this because otherwise I have only two choices. This this kit in the garbage or pay for professional assistance.
I am doing this at home and I just got a baby boy so its difficault, if you know what I mean..
I damaged one LED so I will have to order a new one. I live in denmark so it takes forever to get the components from the stated. I will try and see if I can buy it locally.
Post by: Deluk on November 25, 2016, 01:34:03 AM
I bought these as spares. Doc said they were the correct ones. £3.30 + £1.99 to Dk.
http://www.ebay.co.uk/itm/5-X-LED-SUBMIN-RED-Part-HLMP-6000-/351609648339?hash=item51dd9174d3:g:HvYAAOxyd8NSa78D
Post by: ideal.hat on November 25, 2016, 01:45:08 AM
Great, thank you. I have places an order for 4x of those.
Post by: ideal.hat on November 25, 2016, 01:46:32 AM
I am just wondering if my issue is difficult to solve by those with good experience or if it is just being ignored?
Post by: Rocketman248 on November 25, 2016, 03:26:38 AM
You have the newer version of the Speedball, whereas a lot of the forum members are experienced with the older version.  Hang in there.  Someone will get you sorted soon.   :)
Post by: ideal.hat on November 25, 2016, 11:01:29 AM
That is a good point. Have a good weekend,
Post by: Deluk on November 25, 2016, 12:54:12 PM
The eBay sale is for 5 off led for £3.30 so if you have ordered 4 you will end up with 20 and it will have cost you about 4 x the money. It confused me too but it does say 5x in the description. Should keep you going for a while.
Post by: fullheadofnothing on November 25, 2016, 02:32:01 PM
What are ALL of the voltages specified in the manual?
Post by: Paul Birkeland on November 26, 2016, 10:54:50 AM
I would also be interested in the voltages at A7 and A8.
You can temporarily disconnect the wires to T1 and T2, then put the 22.1K resistor back in place.  Does this resolve your issue?  (I suspect it will not)
Post by: ideal.hat on November 27, 2016, 03:53:20 AM
The readings are the following, I did them again to respond to you.
I notice an different reading on OA. See below.
OA= -0.2 to -0.4 (Problem) Expected=60-90v
IA= 179,4(OK) Expected=170-270V
B-A/B= 0V (OK) Expected=0V
IB= 179,4V (OK) Expected=170-270V
OB= 74,4 (OK) Expected=60-90V
Source= Page 19 in the Speedball 1.1 Manual
Post by: ideal.hat on November 27, 2016, 04:08:06 AM
I have been back and forth in  the manuals and I cannot terminal T1 and T2. Can you please describe them a little so I can locate them?
Could it be that T1 and T2 do not excist in my build since I have version 1.1 of the Speedball?
"then put the 22.1K resistor back in place"
I believe you mean both 22.1K resistors. I will "rollback" the speedball update and report back.
Here are fresh measurements.
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
A8= 0 (Nothing is connected to this terminal)
Speedball v1.1 = "Small Circuit Board"
Post by: ideal.hat on November 27, 2016, 04:25:48 AM
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
"I believe you mean both 22.1K resistors. I will "rollback" the speedball update and report back."
I can unfortunately not do the Speedball rollback because I have just broken one of the 22,4K resistors. :(
Post by: fullheadofnothing on November 27, 2016, 05:35:57 AM
T1 is terminal 1. T2 is terminal 2. So on and soforth theough T22.
Post by: diynewbie on November 27, 2016, 10:27:53 AM
It might be best to let those familiar with the new set-up give advice.  But since others have chimed in ....
I believe you have been requested to disconnect the input and output leads on the photo left side of the speedball  board at terminals 1 and 2 (T1 & T2 in the old manual refers to the lowest terminal strip which is attached to the nine-pin socket (transformer at top).
Then replace the 22.1k resistor on the left side only, across T1 & T2 or (1U and 2U may be used in the manual to refer to T1 & T2).
In effect, the right side in your photo would run thru the speedball while the left side would be the stock set-up.
Post by: Paul Birkeland on November 27, 2016, 02:54:57 PM
Crack:
A1= -0.3
A2= *
A3= 0
A4= *
A5= *
A6= 0
A7= 55,6
Well, there should be an LED connected to A8.  When you get the *, you may need to increase the range on your meter to read the voltage properly.  I'm now very interested in what the actual voltage is at A2.
-Paul
Post by: ideal.hat on November 28, 2016, 08:08:23 AM
Just to recap the current situation.
1. The Crack was working perfectly before I started on the speedball version 1.1 upgrade
2. I have only completed installing the Speedball 1.1 (small circuit board(Formerly v. 1.0, I believe it was two separate boards))
3. I am currently on page 19 in the Speedball 1.1 manual. On that page I have to do measurement and it is there where I have my problem.
    Terminal AO gives me a bad value = -0,2V so I will not go further in the manual until I have resolved this or someone tells me otherwise :)
I just made the following measurements
Crack:
T1=-0,8
T2=179,8
T3=0
T4=180,2
T5=0
T6=0
T7=56,9
T8=0
T9=103
T10=0
T11=0
T12=0
T13=179,4
T14=0
T15=195,7
T16=0
T17=8,85
T18=80,1
T19=80
T20=0
T21=212
T22=0
A1=75,3
A2=0
A3=1,55
A4=0
A5=0
A6=-0,06
A7=0
A8=0,96
A9=-0,05
B1=-0,98
B2=178,5
B3=56,7
B4=75,2
B5=178,8
B6=102,9
B7=0
B8=0
OA= -0.2 to -0.4
IA= 179,8
B-A/B= 0
IB= 179,7
OB= 74,8
Post by: ideal.hat on November 30, 2016, 08:53:40 AM
-Paul
That is correct. the LED is connected to A8.
A8 measures = 0,96
A2 Measures = 0
See full list of measurements above.
Post by: Paul Birkeland on December 01, 2016, 12:53:54 PM
Can you swap the connections at OA and OB?  You may have to tack on a temporary jumper to make these reach, but this will tells us if the problem is on the board or on the amplifier.
Post by: ideal.hat on December 02, 2016, 08:43:02 AM
I have done as you suggested and here are the results.
There were few things that I noticed after swapping OA and OB.
When OA and OB are connected normally, LED A3 is ON but LED A8 is OFF.
When I swap OA and OB. LED A8 is ON but A3 is OFF.
LED D1 on Board A is OFF, before and after swapping.
There is a slight reading difference on OA.
Readings OA/OB swapped
OA= -0,06
IA= 182,4
B-A/B= 0V
IB= 182,2V
OB= 74,8
Readings  OA/OB no swap
OA= -0.2 to -0.4
IA= 179,8
B-A/B= 0
IB= 179,7
OB= 74,8
Post by: ideal.hat on December 06, 2016, 03:43:31 AM
I am still dealing with this and my Crack is nothing more than a beautiful table decoration at the moment:(
Can somebody please help me, I would be ever so grateful.
Post by: diynewbie on December 08, 2016, 02:37:58 AM
I'll bump this for you.
My guess would be something wrong on the A board.  The suggestion above of disconnecting the A side from T1/1U, T2/2U and replacing the 22.1k resistor across those terminals should confirm this.  I would expect both socket LEDs to light up and better voltages at A6, B1 and B3.  I would suspect the D1 diode or 2N2907 transistor.  Since you wrote that new diodes were ordered, you might want to try replacing that diode if re-flowing the joints on those two components doesn't/didn't fix the issue.  BUT, I know very little about electronics.
Best would be if someone who knows something about this stuff answered this thread.
Post by: Paul Birkeland on December 08, 2016, 10:20:57 AM
Yes, there is an issue either with the small PC board, or with the wires that connect it to your Crack.  If all else fails, you can contact replacementparts(at)bottlhead(dot)com regarding a replacement PCB.b
Post by: ideal.hat on December 09, 2016, 03:15:36 AM
Thanks for the bump and feedback.
I will give this a close look over the weekend and report back.
Post by: ideal.hat on December 11, 2016, 03:40:06 AM
SOLVED!! the problem was the D1 diode, thanks for the tip ;)
Post by: ideal.hat on December 11, 2016, 03:44:13 AM
Finally, me issue has now been resolved, thanks to this great community here.
For those interested, I attach some pictures of my Crack setup.
... This is going to be a great Sunday :)
Post by: kgoss on December 11, 2016, 04:14:54 AM
I really like the combination of the black paint and the finish you did on the base.
Nice job. Enjoy!!!
Post by: ideal.hat on December 11, 2016, 04:55:32 AM
Nice job. Enjoy!!!
Thank you, The credit goes to my dad.. He helped me with the woodwork this summer when I was visiting him in Iceland.
He is a well skilled handcrafts man.
Title: Re: SOLVED = Speedball Upgrade. 2 LEDs are off = D1 Diode was not functional.
Post by: Deluk on December 16, 2016, 12:58:00 AM
Out of interest, did you use one of the eBay LED's as replacement for your u/s one? Would be good to know if they are correct as I have added some to my spares box. Thanks.
Post by: ideal.hat on December 16, 2016, 01:02:24 AM
Deluk: I bought these as spares. Doc said they were the correct ones. £3.30 + £1.99 to Dk.
ElGringo81: Yes correct. I did and they work perfectly. Thank for pointing me in the right direction there :)
Post by: Deluk on December 17, 2016, 12:59:04 AM
Thanks for the confirmation, good to know that there is currently a European source at a not unreasonable price. I have to fit my Speedball yet, probably over the Christmas period, but would rather not have to replace any of them on those boards either.
