Bottlehead Kits => Crack => Topic started by: sanchox on January 17, 2017, 06:49:23 AM
I finished my Crack build nearly a month ago, and only in the last couple weeks have I encountered an issue. Now, usually during the first 20-30min after turning the Crack on, I will get crackling and popping that is seemingly random. It will randomly return, but typically it is far more sporadic after use. I went the chopstick route and found that if I tap or wiggle the black wire that goes from 3L to the bottom of the headphone jack I get the exact crackling and popping. If I move the wire a bit more, the LEDs turn off.
Should reflowing this wire and its multiple connections to the headphone jack solve this crackling/popping?
Yes.
Done, and so far so good! Upon close inspection, the first connection to the headphone jack was pretty weak. I filled it nicely and now my Crack is no longer crackling! Smooth as butter.
