Bottlehead Kits => Crack => Topic started by: richie60 on February 15, 2017, 03:45:46 AM
Hi, newbie here, just built the crack with the valab stepped attenuator, all went well, passed all the voltage and resistance checks. Plugged it in to the system connected my phones and turned it up one notch from what I presume was the minimum position only to be blasted at maximum Volume!
As far as I can see, I've wired it up correctly. Is there a way to fully test the volume control because I think it's faulty.
What headphones are you testing with? Ear buds can be very sensitive.
The other question is what happens when you turn the volume clockwise? If it gets quieter the volume control is wired backwards. Someone with the Valab will have to confirm wiring, but it looks right to me.
What value did you order (10K, 50K, 100K, etc)?
HD650. At the minimum setting it's silent so would seem logical that it's wired correctly. Didn't attempt to turn it clockwise because as soon as I got blasted with loud sound I immediately turned it back to the off position and shut the amp down.
I ordered the 100K attenuator.
There’s probably a better way, but I would think that you could do resistance measurements with the unit off. First verify continuity for all of your grounds. Then start at full counter clockwise position when viewed from the knob.
Resistance from in to ground should remain ~100k at each step. Record resistance across in to out and out to ground. I would expect out to ground resistance will increase at each step clockwise and in to out resistance will decrease with each step clockwise. You should see the ratio of r2/(r1+r2) increase with each step where r1 is in to out resistance and r2 is out to ground resistance.
OK. I only did 5 steps as I could see a pattern forming - input to ground on all 5 was 99.6, both left & right input to output was 99.6 and both left & right output to ground measured 0.
I take it that the volume control is faulty. Never mind, I've just contacted the seller on eBay and notified them of the fault and hope I can return it for a working replacement...
Perhaps my suggestion was wrong and the attenuator needs to be isolated from the circuit. An output to ground of 0 with an input to output of 96k would result in little to no sound and you would have not have been blasted on the first step. It doesn’t make sense that the in to out would be 96k for different positions.
Maybe try checking the continuity of the wires and traces. It looks to me like the their red wires are for the input and white wires are output. So you should see little to no resistance from your Right RCA In to the In solder spot and to the highest red wire by the resistors. Similar results for the Your output wire to the output solder spot to the highest white wire.
EDIT
Actually the first few resistors from input to output may be the same. The output to ground resistors will change and likely be low in value. So, if your meter isn't auto ranging, you will have to lower the range to measure the resistance. It looks like the outer resistors are output to ground and the inner resistors are input to output. Try measuring across the each of the upper pair of resistors at position 2 to see what values to expect.
Or try what did with the attenuator in the next to last position - all the ways clockwise then counterclockwise one step.
OK, ignore my readings previously, was tired and the DMM wasn’t set up on the right settings...
I've attached the true readings below in a .PDF file.
Note that when I turned the switch to position 1, I got max volume in the right channel, this reads infinity on the multimeter so I think I can pretty much guess that the VALAB attenuator is faulty!
I would like to thank you for helping me figure out the fault.
Rich
I’m getting out of my depth here. For the most part the numbers look okay except that:
1. input to output values should be in kilo ohms
2. left output to ground at position 17 should be 14.98k instead of 4.98k.
Position 0 doesn’t make sense. I would have expected the reverse of position 23; i.e. 96k ohm for both R/L input to output and 0 for output to ground.
The only bad value appears to be R output to ground at your position 1 label. This could be a bad resistor or a bad solder joint if you are seeing infinite resistance. If you can’t get satisfaction from the seller, you could try reflowing the solder for that resistor or replacing it if it is bad.
Better still would be someone with more experience to comment.
If the functionality or hookup of the Valab attenuator is in question, the best resource for getting that sorted would be - you guessed it - Valab.
http://contact.ebay.com/ws/eBayISAPI.dll?FindAnswers&requested=vintage_audio_lab&_trksid=p2050430.m2531.l4583&rt=nc&iid=311796035728 (http://contact.ebay.com/ws/eBayISAPI.dll?FindAnswers&requested=vintage_audio_lab&_trksid=p2050430.m2531.l4583&rt=nc&iid=311796035728)
Input to output values are in Kohms, just didn't mark them down as such, apart from that all readings are what they are. Had no reply from the seller as of yet, don't expect one either so am probably going to ditch the Valab in favour of another pot. Quality control seems to be a bit iffy on them.
Do you measure continuity between all of the black wires?
Do you mean all of the ground wires connected to the PCB the yes, there is continuity between them all.
I wonder if the PCB on top is wired backwards, i.e. the input and outputs are the wrong way around.
Also i don't like the tube cathode terminating at the attenuator, i would prefer it on the middle post of the terminal strip as per the manual.
Are you able to reduce the volume via your Cracks source? If you can lower the volume via your pc or player software you would at least be able to then test to see if the attenuator as any effect at a reduced volume as its switched from step to step.
I did think of that, but I can't lower the volume at source as I don't use a pc. My main source is a Pioneer N50 network player or turntable.
Your readings indicate that the makers wiring is correct. I don’t know if your wiring is correct.
Are you sure that position 0 is 0 for input to output? You reported it as 99.6 kohms in an earlier post. A 0 value would indicate no attenuation and you should have been blasted with sound in both channels. Recheck position 17 as you have two different values for output to ground; they should be the same – ca. 14 kohms.
Keep in mind that there are only two resistors per channel in circuit at a given time. The exception would be the first and last positions which will only have one resistor and a wire and their positions should be reversed. So, all other positions should work fine. If you have some cheap headphones, you could skip the bad position and start with the next. This would at least show that your wiring is correct.
If you can contact just the top lead of the top resistor – closest to the pcb board, you may be able to determine if the resistor is bad by measuring resistance between it and the joint between the two resistors. Of course, if that solder joint is bad, you will still see infinity. Check the resistor closest to the bottom pcb as well to make sure you have the correct resistor. If both are fine – i.e. ~99 ohms not kohms, then it is a bad solder joint.
The faulty position isn’t one you are likely to use, so I wouldn’t pitch the attenuator if the seller won’t replace it. Once I knew the seller won’t replace the unit, I would try reflowing the solder at the top pcb, then, if that didn’t fix the reading, reflow solder between the two resistors. If you don’t want to replace the bad resistor, you could remove it and replace it with a wire. The sound wouldn’t be balanced at that position, but you shouldn’t get blasted in the right channel, it would be the same as the previous position for that channel. The attenuation of the left channel at the bad position is -60dB and not likely to be of any practical use.
Right. I've had a poke about with the multimeter again, on 17 position, it reads 14.9 on both channels, must have read it wrong when I wrote it down first time I tested it. I can confirm the readings are 0 with the switch turned all the way down between both the input and output.
Where I had an infinite reading on the right channel, now shows 99-100, maybe I've disturbed something I don't know. The resistors measure ok. I don't trust this unit at all.
I can’t say that I blame you. If the initial problem was a cold joint in the right channel, the joints would still need to be reflowed before I would trust it. But I can’t see how you could get 0 ohms for input to output and output to ground at the lowest setting. This would also concern me.
I’m also not sure what the effect of a cold joint would be. I think that circuit should look like the RCA ground going to the socket and the RCA pin in line with a the socket with a 96kohm resistor in between. I’m not sure if this would blast that channel.
Like I said, I’m out of my depth at this point. Hopefully you will get a favorable response from the seller.
Cutting my losses on this one. Think i'm going to order a normal decent quality Pot!
Still had no reply from the seller. Won't be buying anything from him again.
I also bought a Valab attenuator from Vintage Audio Lab and could never get it to measure to what I expected (it was the SMD version). Tried a couple times to contact the seller and never got a reply. Just today I installed an Alps Blue Velvet to replace the stock pot in my Stereomour and for a cheap, direct replacement I like it. Definitely resolved my channel balance issue. Can't say it sounds that much different than stock but it sounds great. I bought the one with lugs for easy soldering. The shaft is a little long - I cut it down by about 5/16".
I used the link that someone posted on the forum a couple weeks ago and got it in about a week from China. It appears to be a real Alps.
Rick
One came with your kit, give it a shot!
Finally had a message from the seller on ebay:
Dear Sir:
Oh, so sorry for my late answer.
I have a bad cold from last week.
This is a one man business. so I fail to process your request until today.
You do not connect it right way, not a defect.
In -> connect to signal source. .
Out --> connect to your signal input of your circuit board.
G -> ground.
You must connect it wrong way.
It is ok, If you fail to use it.
I will issue full refund to you.
Sincerely, Kevin
He must think I'm an idiot! Think I know how to wire up the PCB on the volume control.
It's reversed somewhere.
For now you could just switch input and output.
This would give you a working volume control that works anti-clockwise for now.
Edit: On second thought, i'm wrong about that last sentence.
Looking at your pic it looks a bit unclear if two of your black ground wires which are connected to the outside edge are connected to the correct ground positions I see other clearly marked ground positions on the pcb just not ones on that outside edge where two of your black leads are connected.
I got the same Valab and installed it in the past month. The outside edge is connected to the ground tab in the middle (R). To me the wiring in the picture seems good.
Update:
I have just installed my new replacement volume control, an Audionote 100K Potentiometer, cost me £36 Inc. Vat & shipping direct from Audionote themselves. Had to widen the hole in the plate a little bit further to accommodate the 10mm thread but that was easy with a round file. Currently sat here listening to some tunes on the amp, all is well...
I'll post some pictures later on...
I would like to thank all of you that have tried to help me figure out the problems I've been having.
Richard
