Changing to a 50K Valab attenuator
Loquah · 4770
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
on: April 03, 2014, 08:24:13 PM
A good friend has offered to sell me a 50K Valab stepped attenuator which I have heard good things about. My only concern is that I currently struggle to get past 25% on the existing (stock) 100K pot. Am I correct in thinking that a 50K attenuator will lead to higher base volume (and therefore even less usable range) or am I getting it wrong?
Offline murray
Reply #1 on: April 03, 2014, 09:12:43 PM
You may not notice much difference.  All pots go from 0% to 100%, the different overall resistance may just change the loading of the preceding stage slightly.  You can adjust the operating range of a pot by adding resistors between the "bottom" of the pot and ground, or between the "top" of the pot and the input.  In this second case it will give you more usable range in your situation.  I have done this to a 10k pot on my sold state headphone amplifier.  The 10k has 33k (I think) resistors between the input and the pot.  This makes the pot "appear" to be a 43k pot which is only at 1/4 volume (-12dB) when the pot is actually at maximum position.
Murray S. (N.Z.)
Reply #2 on: April 04, 2014, 12:32:00 AM
In a word, No!  Regardless of the attenuator value it will still work like the stock pot.
But you are in luck, you chose a lower value, just put a 50k Ohm resistor in series with the lead from the inputs' hot lead to the attenuator.  This will give you more usable range on the attenuator.
I would suggest you buy several pairs of resistors and use clip leads to attach them.  When you find the ones that are right for you solder them in.
Try a pair of 50k, 100k & 200k Ohm resistors.
« Last Edit: April 04, 2014, 02:22:45 AM by Grainger49 »
Offline Loquah
    • Passion For Sound
Reply #3 on: April 04, 2014, 01:52:25 AM
Thanks both. I was worried that adding resistors might alter the sound. Is this the case?
I can buy the same attenuator in 250K guise. Would this be a better option?
Reply #4 on: April 04, 2014, 02:23:56 AM
The resistor will add some flavor, a little bit.  So find the value you want and buy a designer resistor.  They are under $10 each.
Offline coca
Reply #5 on: April 04, 2014, 04:10:10 AM
Does anybody know where a Vlab step attenuator can be purchased/
Bernie.
Reply #6 on: April 04, 2014, 04:12:56 AM
Bernie,
They sell on ebay.  Look here:  http://i244.photobucket.com/albums/gg7/Grainger49/Smiles/ROLF.gif
The attenuators are shown on that page.
Reply #7 on: April 04, 2014, 05:12:06 AM
Hi Loquah,
I highly recommend you buy this version http://www.ebay.com/itm/Assembled-Dale-23-Step-Attenuator-Volume-Control-100k-/270311271326?pt=US_Amplifier_Parts_Components&hash=item3eefceab9e as it uses Dale resistors which i always found to be the most transparent. If i am not mistaken the BH guys used them in the mainline attenuator.  It doesn't have the nice PCB's that the Valab version has but the better resistors are more important IMO.
As for using 50k or 250k, best to ask the BH guys.  PB did confirm that 75k was absolutely fine on the S.E.X. amp.
w0lfd0g
Reply #8 on: April 04, 2014, 12:09:42 PM
Why not buy a BH Submissive  ;)
Offline Loquah
    • Passion For Sound
Reply #9 on: April 04, 2014, 02:09:43 PM
Hi Loquah,
Thanks for the link mcandmar. That is a perfect fit - 100K and as you say, the same resistors as used in the Mainline. Thank you!!
Reply #10 on: April 04, 2014, 04:05:09 PM
I've used them in a few amps, bargain for the money as it would cost as much for me to buy the resistors on their own from Mouser.  I've actually just upgraded my S.E.X. amp to a Goldpoint ladder attenuator, details in my main thread here http://bottlehead.com/smf/index.php?topic=5316.msg58412#msg58412
