Just finished installing speedball and have voltages a bit high.
timindq · 1935
Offline timindq
On the large board OA voltage is +107 and on OB voltage is +106. The B+ voltage is within tolerance and ground is 0.  Resistance checks are fine everywhere. I listened to it and all is good. Music sounds fine and without music playing the amp is dead quiet.
When I did the initial voltage checks with the Crack build all voltages were well within tolerance. Should I be concerned?
One more bit of info. The AC mains voltage in my house is notoriously high. My main system is plugged into a Furman PL-C with voltage readout which usually runs 126 VAC.
Source: Lumin D2 with SBooster power supply, 2tb SSD attached to Lumin, Pre: Moreplay, Amp: Bryston 2bSST, Speakers: Joseph Audio RM22XL. Setup in large, well treated dedicated listening space.
Offline timindq
I listened to the Crack for about an hour last night with no issues. After rereading the manual I see the (+/-) 10% tolerance so maybe I'm worried for nothing. Still, I would love it if one of the pros gave me the thumbs up.
One mire bit of info: voltage readings on the small board were good during initial test. I did not recheck the small board after large board installed.
Those voltages are a little high, but not out of the ordinary.
Offline timindq
Thanks for reply. It's been in use for the last few days with seemingly no ill effect.
