Driving the HifiMAN HE-5LE
Spinifex · 4777
Offline Spinifex
on: September 06, 2010, 03:01:16 PM
Hey,
I just wanted to know if anyone has experienced driving the new Orthodynamic headphones with their S.E.X. I have recently purchased a used pair of HE-5LE, and my Hagerman Castanet is having some difficulties with them: I can easily push the volume to maximum and still be within my comfortable zone.
For reference, here are some specs (from Headroom):
Impedance @ 1kHz: 38 Ohms
Sensitivity: 87.5 dB
Cheers.
Online Paul Joppa
Reply #1 on: September 06, 2010, 05:53:52 PM
Looks to be a bit on the low sensitivity side. The SEX amps with the standard 129 ohm resistor would be marginal, but you can reduce or eliminate that resistor, which with 40-ohm 'phones will give you another 12dB. That's 400 milliwatts, giving 113.5dB capability. Should be enough ...
Offline Spinifex
Reply #2 on: September 07, 2010, 05:55:52 PM
Soes removing the resistor have any negative effect on the sound quality? Is it dangerous for the headphones on start-up? Since I do not have much electrical knowledge, I want to make sure before I make any change to designs.
Online Paul Joppa
Reply #3 on: September 07, 2010, 08:11:43 PM
The 120 ohm resistor is a standard, IHF in the past and IEC currently. As far as I know, its only purpose is to keep low-impedance phones from being excessively loud compared to high impedance phones. It has little effect on high impedance phones, but greatly decreases the damping factor along with the signal level on low impedance phones. So it imposes an extra constraint on the design of low-impedance phones.
All these standards are from a pre-iPod era. iPods and other small portables have low voltage batteries and can't put much power into a headphone unless the phone impedance is low and the source impedance is very low. In other words, the standards are out of date. More and more phones are low impedance so they can work with low voltages, and many of them are not actually very tolerant of a high impedance source. The standards have become obsolete, and more and more manufacturers are ignoring the extra constraint.
Bottom line, you can yank the resistor if you want, it will probably improve the quality of the sound. If you have very sensitive low-impedance phones they will get too much signal, and even the very quiet SEX amp might make too much hum and/or tube rush noise. In that case, you'll want to keep the resistor, or substitute a suitable low-impedance level control. But in the case of the subject lower-sensitivity phones, yanking the resistor is probably the best sounding option.
The SEX amp is transformer coupled, which reduces the risky startup transients to insignificance. You are right and prudent to ask about it since there are headphone amps which do have such transients, and modifications might exacerbate them.
Offline Spinifex
Reply #4 on: September 08, 2010, 05:38:08 AM
Much appreciated. I'll be following your advice if I buy a S.E.X. kit. I might still just skipt it and go straight for the Stereomour. ;)
« Last Edit: September 08, 2010, 09:33:17 AM by WyldRage »
