output coupling capacitor
borism · 4556
Offline borism
on: June 14, 2017, 07:39:06 AM
Hi,
I have finally started putting together my Eros kit. First, a shout-out to Josh who has somehow managed to get all the right little parts and in the right number into the kit.
My question is regarding the outside foil orientation of the output coupling capacitors (for upgrading purposes). I assume they should be connected to the low impedance side of the circuit. What terminal numbers does that translate into and why?
Boris
Offline Sugar Man
    • The Last Honest Lawyer
Reply #1 on: June 15, 2017, 03:10:35 PM
Not sure if this helps, but I asked this on the Stereomour II forum.  Make sure to read all the way through, because there was a bit of confusion (all caused by me)
http://bottlehead.com/smf/index.php?topic=9124.0
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Offline borism
Reply #2 on: June 16, 2017, 11:02:42 AM
Well, I've completed the amplifier. It passed all resistance and voltage tests and is currently playing - beautifully as I may add - in my system.
I have solved the outside foil capacitor question to the best of my ability, concluding that the low impedance terminals are numbers 9 and 10. They are connected to ground through the 47K resistors.
Here are a few pictures of my build.
The base is bubinga wood.
Boris
Reply #3 on: June 16, 2017, 11:37:06 AM
It's kind of funny, those terminals are generally the lowest impedance to ground, but you could plug your Eros into a load that's much less than 50K, then things get switched around.
Is that the stock alder base dyed/stained, or custom wood?
Offline borism
Reply #4 on: June 16, 2017, 11:46:25 AM
Thanks, it is a custom bubinga base I made to complement my Bottlehead system consisting of Stereomour, Crack and now Eros.
Boris
Reply #5 on: June 16, 2017, 11:49:10 AM
That's a nice looking trio!
Yeah, I was going to implore you to share the details of how you could get alder to look like that!
Offline borism
Reply #6 on: June 17, 2017, 04:14:33 AM
I am also wondering if there are any sonic benefits in upgrading the 0.1 uF capacitors on the shunt regulator board. I have some Russian FT-3 teflon capacitors sitting around.
Let me know what your experience is.
Boris
Reply #7 on: June 18, 2017, 01:08:27 PM
I recall a long time ago hearing an improvement with the 0.056uF FT-3 caps. Worth a try if you can find room for them.
Offline borism
Reply #8 on: June 19, 2017, 03:46:39 AM
Thanks Paul! I'll probably try it out. At this point I've put in some Telefunken EF86s and am enjoying the sound.
Boris
Offline borism
Reply #9 on: June 23, 2017, 03:42:35 AM
One, hopefully, final step for this Eros build was replacing the electrolytic cathode bypass with film caps (Jantzen, 82 uF) and the 0.1 uF shunt board capacitors with same value Russian FT-3s. I was happy that everything fit and the amplifier works. I will need some time to hear if there is any detectable sonic benefit to this.
However, what a fun project!
Boris
Offline JamieMcC
Reply #10 on: June 25, 2017, 12:47:10 AM
Nice work Boris the Eros is a great bit of kit, mine also has a Bubunga base and a few cap upgrades it still impresses every time I listen   :)
Offline borism
Reply #11 on: June 25, 2017, 03:35:27 AM
Hi Jamie, your build was one of my inspirations. It's beautiful. May I ask where you found the "Russian candy" RIAA 600V caps? When I looked on eBay I could only see the 200V version.
Boris
Offline JamieMcC
Reply #12 on: June 25, 2017, 08:34:47 AM
Hi Boris thanks.
I found the 600v Teflon caps for the RIAA on ebay if you have not done so try searching for them using their nf, or pf values instead of the uf value.
http://www.radio-electronics.com/info/formulae/capacitance/capacitor-conversion-chart.php
Cheers
Jamie
