General Kaiju Questions
Kyngfish · 3164
Offline Kyngfish
on: July 11, 2017, 07:21:54 AM
Hi,
If this needs to go to the general discussion section, apologies, but just a quick question. I posted a question about which amp to go with and I thought I was pretty much set. A few days later I have a few doubts.
The Stereomour goes to 3.5 watts per channel. My 96db sensitivity speakers live around 1/3 (moderate level listening) to 1/2 (probably a bit loud) on a 6 watt per channel (into 8 ohm) T-Amp, so that's AWFULLY close to that 3.5W threshold. (Assuming dial position corresponds to % wattage).
Is the Kaiju a better option? If the only difference is that cost in the standalone amp, then I was considering it as a good alternative. But I noticed it didn't say integrated amp, does that mean I would NEED to have the preamp as well?
Martin
Offline denti alligator
Reply #1 on: July 11, 2017, 07:25:43 AM
Yes, there's no way to control volume otherwise. You can get a passive or active. The cheapest would be a Quickie, which is pretty great.
- Sam
Reply #2 on: July 11, 2017, 07:38:39 AM
This is a pretty common misconception.  The volume control position has almost nothing to do with power; I say almost because if it's all the way down, then you know your power level.
Consider the following scenario:
You put the level control on your T-amp 1/4 of the way up.  You play a song from your phone, and your phone has 0.3V of signal output.  You then hook your phone up to a DAC and play the same song, but the DAC has a 3V output.  Without moving the level control, you're now 20dB louder than you were before at the output of the amp.  This is 100 times more power, just based on the output voltage of your source, but the question remains whether your amp can make that excess power without clipping.  If we assume that with the level control 1/4 of the way up on the T-amp that this is the perfect spot where the T-amp has 0 voltage gain (which is plausible), then you will go from 1/8W with your phone hooked up to 12.5W with your DAC hooked up.  With the DAC, the amp will be clipping, and you'll have to turn the level control down.
The Kaiju is by far a better amp! The transformer quality is quite a step up from the Stereomour, and even if you don't need the extra power available, distortion will be lower at a given listening level when compared to the Stereomour.
You will indeed need a preamp to go with the Kaiju, and I wouldn't scoff at pairing the $99 Quickie with the Kaiju (in fact, I may give that a try tonight, as I haven't listened to that combo myself just yet).
Offline Kyngfish
Reply #3 on: July 11, 2017, 08:16:03 AM
Splitting the difference, would the Smash also be OK? What's the battery life with the Quickie?
Reply #4 on: July 11, 2017, 03:56:51 PM
Quickie battery life is about 100 hours on both the D cells and the 9V batteries.
The Smash is also a great choice!
Offline gaddism77
Reply #5 on: February 09, 2018, 06:18:17 PM
Does the kit come with tubes? If so, what make?
Thank you,
Matt
Offline BNAL
Reply #6 on: February 10, 2018, 04:34:43 AM
The Quickie comes with 3S4 tubes, but does not come with the wood base.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Reply #7 on: February 10, 2018, 08:28:02 AM
All our kits come with tubes.  Since three kits have been mentioned in this thread, I'll mention what comes in each:
Quickie - new old stock 3S4s.
Smash - new old stock 4P1L and new/used old stock 0D3
Kaiju - new old stock 5670, Electro Harmonix 300B
