Hissing BeePre
elko · 2195
Offline elko
on: August 13, 2017, 10:24:48 AM
Since i fixed my humming problem in my left channel. I noticed another noise from the left channel only. In the left channel there's always a hissing noise present. I really want to get rid of it because its noticable in quiet parts of music. What steps do i need to take to diagnose the problem. Should i do a complete voltage & resistance check and find out of there are any differences in the left and right side? The right channel is dead quiet.
Best regards
Offline Alonzo
Reply #1 on: August 13, 2017, 01:01:59 PM
Are you sure it's from the BeePre?  Swapped sources/channels/tubes?  If your BeePre measures within spec, check your source and amp for amplified background or interference being picked up.
Alonzo
Offline elko
Reply #2 on: August 13, 2017, 09:49:16 PM
I turns out to be one of the tubes. Feel a bit stupid that i havn't checked first. Thought it was obvious there was something amiss with the left part the circuit since the hum came from there to.
Thanks for helping me out!
Reply #3 on: August 14, 2017, 04:44:31 PM
Sometimes a few hours of running time will do a lot to quiet down a tube (even a new one).
