Bottlehead Kits
Crack
Speedball just finished - two voltage readings off.
drewhaynes
1465
drewhaynes
Full Member
November 19, 2017, 05:19:16 PM
I got to the final step of the speedball upgrade... but it indicates that OA and OB should be reading 75-100V... OA is reading 118V and OB is at about 115V. Everything else has measured as expected, all 8 LED's lighting up, etc.
Should I try headphones? Is this a bad sign?
Drew
Paul Birkeland
Global Moderator
Hero Member
Re: Speedball just finished - two voltage readings off.
Reply #1 on:
November 19, 2017, 05:19:46 PM
How are OA and OB on the small PC board?
drewhaynes
Full Member
Reply #2 on:
November 19, 2017, 05:23:53 PM
OA = 82.5V
OB = 83.5V
These are on the small board hovering over the small tube.
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
November 20, 2017, 03:43:28 AM
You should be OK to use your amp.
drewhaynes
Full Member
Reply #4 on:
November 20, 2017, 03:45:43 AM
Awesome! Look forward to trying it tonight. I tried to be careful and my soldering has much improved since the original Crack build. I wonder why those two terminals (OA OB) are reading higher than spec!
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
November 20, 2017, 03:52:05 AM
They react a bit to the voltages at OA and OB on the front board, along with the actual 6080 itself, so there's some room for those voltages to move around a bit.
tsh
Newbie
Reply #6 on:
November 30, 2017, 12:16:00 PM
Similar situation here: on the large board OA=112V, OB = 116V, on the small board OA = 81V, OB = 78V. Can I consider it normal? All other readings are within tolerances. My mains voltage is 230V.
Taras
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
November 30, 2017, 12:46:19 PM
Yes, no problem there.
Bottlehead Kits
Crack
