Bottlehead Kits > Kaiju Stereo 300B amp
Kaiju Headphone Amp
Bartman:
I second the previous posts recommending the DC Kit for the Kaiju if it is being used as a headamp. For me there was way too much hum using headphones with the stock Kaiju even though I heard no hum through speakers. When I installed the DC Kit it became quiet as can be - no hum at all.
Question: My Kaiju is currently wired for 2 Ohms. Believe it or not the Hifiman Susvara (83db) could use little more volume for some recordings. Would wiring it for 4 or 8 ohms give me more volume?
Thanks Bottlehead for such a great product!
Doc B.:
It's possible that rewiring will give you more volume from the headphones. But in this case you need to asses whether the issue is a lack of drive from amp into headphone, or not enough signal level from your preamp to the Kaiju. Are you turning your source volume way up but not getting a high enough level, or is the Kaiju going into clipping before getting the headphones loud enough?
Bartman:
The Kaiju is definitely not clipping. When I turn the source volume up to near full volume I am not getting quite enough volume.
Doc B.:
Going to a higher output impedance configuration may help, but ultimately you may need to figure out how to get a higher level signal into the Kaiju.
Bartman:
I'll try the re-wire. I may also have a DAC/preamp that has higher output.
thanks!
Navigation
[0] Message Index
[#] Next page
Go to full version
