Another Left Channel intermittent post
Bryon · 6561
Reply #15 on: March 23, 2018, 09:04:02 AM
A lot of the process involves checking voltages when the problem occurs. When you hear the signal playing half as loud check the plate voltage of the 300B at pin 2. I wonder if there might be an issue with the output capacitor on that channel.
Reply #16 on: March 24, 2018, 07:17:29 AM
Can you tell us what your line voltage is?  If it's borderline on the low side, turning on the Crack may be temporarily aiding in a low line voltage situation.
Offline Bryon
Reply #17 on: March 25, 2018, 06:56:37 PM
Both channels have been playing without interruption for about 6 hours - Yay!!!
I decided to transplant the C4S board from my working Beepree first.  It played perfectly for about an hour and then the left channel went missing again.  Next transplant was the Filament Regulator board and miracle of miracles, it worked.
I am still left with a Beepree [the transplant donor not the recipient] that isn't going to work consistently on the left channel, but at least now I have a general idea of what is causing the problem.
Now that it is narrowed down to the Filament Regulator board, is the most likely candidate for replacement the LM1085 [as it is the only thing on the board that needs a heat sink] or one of the other transistors or regulators?
thanks PB, Dan and James for your support and suggestions - as always you guys rock.
Bryon
I
« Last Edit: March 25, 2018, 06:58:19 PM by Bryon »
Reply #18 on: March 26, 2018, 03:48:03 AM
It's hard to say what might not be working without knowing what kind of voltages you were seeing.
When I have servied BeePres with filament voltage issues, more often than not it has been a flaky solder joint on the 6 lug strip under the filament regulator board where the two 10,000uF caps hang out.
I have never had to replace a 1085 regulator in anything I have ever worked on.
Offline Bryon
Reply #19 on: March 26, 2018, 08:46:40 AM
Given that after the board was exchanged, the problem disappeared, the problem seems to have been a component on the board so probably not an issue on the lug board.   Are any of the other components on the board likely to be heat sensitive?  Dan mentioned a possible cap issue - so maybe the .22uf?
What voltages would help you diagnose the culprit.  My line voltage is high - 121V.  I did all the voltages a week ago so I can give you any relevant numbers from then.  I did notice a change in Pos out and Pos in.  Voltages were Pos In - initially 140V settling to 137V and 9.98 on the Pos Out rather than the 8.6 that I had measured before.  That seems high but the channel was working at that point.
thanks again
Bryon
Reply #20 on: March 26, 2018, 09:17:57 AM
Do you have the feet on the base, to allow some air flow under the chassis?
Offline Bryon
Reply #21 on: March 26, 2018, 10:15:02 AM
The base is on sorbothane feet and then elevated a further 3/4" on anti-vibration pads so there should be lots of ventilation.  Earlier in the process, I elevated them another inch or so to make sure there was enough air flow but it did nothing to solve the problem.  The Beepree also has room on each side and the top for air flow.  The only thing I can think of is that maybe I overheated one of the components on the board when I was soldering it, not enough to kill it dead, but just enough to injure it to the point of exhaustion after an hour
Bryon
Reply #22 on: March 26, 2018, 10:30:22 AM
The connections on the terminal strip will get nudged when swapping out boards, so this is still a real possibility.
The 0.22uF cap is in the high voltage regulator circuit, so no issues there.
Nah, that's perfect.
Pos In should be 10-15V.  The voltage that's approximately 150V will develop on the other half of the board that holds the TL431.  Having 8.6V on Pos Out would indicate that something in the low voltage circuit needs some help.
Reply #23 on: March 26, 2018, 11:16:42 AM
I seem to recall the prototype needed to have its 33µF and 150µF caps changed after a coupla thousand running hours. You could start there...
Offline Bryon
Reply #24 on: March 26, 2018, 01:25:40 PM
The bad news - the left channel has disappeared again after 3 hours play time today.
PB - I missed seeing a decimal point on the Pos In - I just remeasured and it is actually 14V on both channels.   The Pos Out is now 9.975 or thereabouts on each side-
You may be right about the connections on the terminal strip - I'll try resoldering them and see.
Josh - thanks for the suggestion to change the 33uf and 150uf caps -it's worth a try
Bryon
Reply #25 on: March 26, 2018, 01:41:27 PM
The 10,000µF 10V were also replaced at some point. Might be more useful since it's now showing to not be the board.
Reply #26 on: March 26, 2018, 01:50:43 PM
Something does not add up. You say the tubes stay lit but the filament supply is dropping out.
Offline Bryon
Reply #27 on: March 26, 2018, 01:58:19 PM
It doesn't make sense to me either - maybe the fact that the channel didn't drop out had nothing to do with changing the filament board and was just coincidental?  Would the tubes stay lit if it was the sockets?  maybe we're back there.
Bryon
Reply #28 on: March 26, 2018, 06:08:08 PM
Ha, yeah, those teflon sockets...  It's really impossible to tell if they are the issue without yanking them out and replacing them, and I'll certainly feel bad if they aren't the cause of the issue!
9.975V and 14V are dead nuts on.
If the tube socket connection gets flaky, you should lose the 5V reading across the paralleled 10W cathode resistors.  I would be probing there next.
Offline Bryon
Reply #29 on: March 27, 2018, 05:40:57 AM
I resoldered the connections to the lug board under the C4S board and the both sides worked for about 5 hours last night so I'm hoping you were right PB and this will be a permanent recovery.   I'm gone for a few days, so I'll update when I get a chance to play it for a few days.
thanks again for all your help
Bryon
