Crackle in the left channel
tagomago · 2041
Offline tagomago
on: March 24, 2018, 10:53:14 PM
I built my crack yesterday. To my surprise there is now always a crackling sound in the left channel.
It's just always there, sometimes more, sometimes less. It does not get affected by the volume pot or the inputs.
I used a wooden stick to find a bad solder joint but did not find any. I resoldered all the joints. But it's still here.
I left it on now for about 15 hours but it's still the same.
Could it be that a tube is bad?
The music does play nicely on both channels, but the crackle is just always underneath.
What else can I do?
Reply #1 on: March 25, 2018, 06:34:30 AM
How were your voltage checks?
This does sound a lot like a flaky solder joint.
As always, you can post photos of your build and we might be able to spot the issue.
Offline tagomago
Reply #2 on: March 26, 2018, 06:49:08 AM
Thank you for your answer
Here are my voltages:
terminal:
1 - 83VDC
2 - 166VDC
3 - 0VDC
4 - 166 VDC
5 - 86 VDC
6 - 0VDC
7 - 105 VDC
8 - 0 VDC
9 - 107 VDC
10 - 0VDC
I redid all the solder joints again now, not luck. I'm very certain that I don't have a bad solder joint. I'm an electronic engineer myself, I solder quite a lot at work.
I used sand paper on the tube pins also for better contact.
Could this be in the sockets? Should I use some contact spray?
What if it's really a tube, how could I prove this?
I don't think it's in the power supply part, that would affect both channels right?
Could this be resolved when I install the Speedball?
Reply #3 on: March 26, 2018, 08:36:49 AM
Can you leave your amp on overnight to see if perhaps it's just a tube cathode forming issue that may pass with some run in time.
Installing the Speedball is not going to fix this issue and should wait until this is resolved.
Offline tagomago
Reply #4 on: March 28, 2018, 07:53:03 PM
I did leave it on for a long time, it got better but after turn it off again it was there really bad.
Yesterday I bought new tubes and the funny thing is the noise was still there.
But I guess I found the reason now. It's one of the 22k 0.5W resistors. If I swap the resistors from one channel to the other it also changes the channel of the noise. This is repeatable. I will get some new resistors today and check again. This is really strange  ;D
Offline tagomago
Reply #5 on: March 29, 2018, 01:05:38 AM
Yup, it worked!! It was the 22k resistor.
