seduction problem
Ed Faulkner · 1787
Offline Ed Faulkner
on: June 11, 2018, 05:31:31 PM
I have a Seduction phono stage (with CCS) that has a low level motorboat sound at very low levels. I have already changed PS caps and the sound persists, anyone else experienced this issue?
Reply #1 on: June 11, 2018, 07:03:52 PM
Have you tried different tubes?
Offline Ed Faulkner
Reply #2 on: June 12, 2018, 11:04:45 AM
Several different tubes and brands have been tried.
Reply #3 on: June 12, 2018, 11:23:08 AM
How are your voltage checks?
Reply #4 on: June 12, 2018, 01:58:26 PM
Did you also replace the heater supply cap, or just the high voltage caps?
Offline Ed Faulkner
Reply #5 on: June 14, 2018, 09:26:51 AM
Voltages all good, heater supply cap also replaced. I need to dig in with a scope and isolate a few things, was hoping someone else had a similar issue I could shortcut from. The thing still sounds great but does not have a black background at high volume, most music swamps the sound. Will dig up the schematic again (somewhere in the shop) and plan a next move. Might even get another kit to use while fixing this one, I hate being without good sound...
Reply #6 on: June 14, 2018, 10:10:29 AM
Clean the tube pins and sockets really well, and inspect the film caps for damage.
Offline Ed Faulkner
Reply #7 on: June 14, 2018, 11:25:50 AM
Will do, thanks for the tip.
