Standard Crack Channel Imbalance + Noise
3ph00n · 8810
Offline Tom-s
Reply #30 on: October 06, 2018, 07:26:01 PM
You can find good 6AS7G/6N13S svetlana and 5963NOS or 5814A to get your Crack "new" tubes @ https://www.btb-elektronik.de/home
Offline 3ph00n
Reply #31 on: February 26, 2019, 09:06:27 AM
Hi everyone,
It has been a long time since I last posted here but for anyone interested and people with a similar problem:
Changing both tubes fixed all the problems I had.
First I exchanged the 6080 for a 6as7g Svetlana and all the problems in the left channel disappeared.
Directly after that a much quieter noise in the right channel appeared (I think it was always there, I just couldn't tell before)
This new noise could be fixed by tapping the input tube.
This was also fixed by changing the tube and finally I got the sound I was looking for!
Thanks alot for all of your help and support and the amp that now works really well!
(Btw: is it possible to file a warranty claim for my issues as the tubes set me back another 40€?)
Offline Tom-s
Reply #32 on: February 26, 2019, 10:23:13 AM
I'm very happy it all worked out for you and Crack is working as it should. It is a great amp indeed! One of the best price/performance ratio's available. And for what it can teach you in the journey of building it and all that comes after, one of the best amps you will ever buy.
Personally, i think buying NOS or old tubes comes with a calculated risk for the buyer. Although most are generally reliable products they have had a long shelf time before you get them. And the noise issues with these old things can't always be checked for. And they can appear after some use without any symptoms prior to that point.
Second. I think a company can't be held responsible for the price you paid for a spare set of tubes. As you can buy tubes for a few cents a piece when you are lucky (or free even), or pay hundreds of euros for a single tube.
I know i'm not making any friends with you right now. This is a personal opinion. This is not at all the Bottlehead company opinion/policy. In general i think the support received from Bottlehead is among the best you can get. They stand behind their products and are always willing to help out a Bottlehead user in need.
Reply #33 on: February 27, 2019, 04:26:02 AM
The challenge that we have is that there are a pretty good number of builders who run into problems and blame the tubes.  Even when a different set of tubes appears to solve the problem, often it comes back at a later time (whatever solder joint isn't properly soldered gets disturbed enough when swapping tubes, then goes out again a few months later).  What we most often found when receiving tube sets back is that they tested perfectly and sounded great.  Occasionally we would need to let a particular tube run in for a day or two to get it quiet.
If we offered to reimburse builders for new tube sets, everybody would buy one!
