Replacing the standard pot with a stepped attenuator?
loz_the_guru · 2975
Offline loz_the_guru
on: October 06, 2018, 11:34:19 PM
Hi all,
I've had my crack up and running for a month or so now, and fancy swapping the standard for a laddered attenuator. Can anyone tell me how complicated the process is, and also if I need a 10k or 50k version? There's quite a few on ebay:
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=ladder+attenuator&_sacat=0
Any real differences between them?
Offline Tom-s
Reply #1 on: October 07, 2018, 04:34:22 AM
The recommended attenuator for Crack is a 100k stereo log ladder type stepped attenuator.
I've used the Valab stepped type with good results.
Reply #2 on: October 07, 2018, 09:53:52 AM
Thanks. Out of curiosity, what does the resistance level do? I usually have my crack under a quarter turned at the moment, as with my HD700s its otherwise just too loud!
Reply #3 on: October 07, 2018, 10:53:28 AM
The impedance of the attenuator has nothing to do with levels.  A 50K attenuator and a 100K attenuator with both pass the same amount of signal into the amp when turned all the way up (assuming you don't have a source with very high output impedance, which is a very reasonable assumption these days).
The Crack circuit works pretty nicely with a high impedance level control like the 100K pot we provide, and 100K is a very easy load for sources to drive, so that is what we use. You could use a 50K control and you likely wouldn't notice any difference.
Offline Tom-s
Reply #4 on: October 07, 2018, 11:17:09 AM
As Caucasian blackp.. wait PB said (did someone decide for a name change?? ) the impedance doesn't change the sound level.
But FAQ #3 (look it up) does. Thing is. This is meant to go with a 100K log. Tell us what impedance you went with and then the resistances for FAQ#3 can be calculated based on that.
This change makes that you get more useful range of your attenuator with your HD700's.
Edit: Link https://bottlehead.com/smf/index.php?topic=4295.0
« Last Edit: October 07, 2018, 11:20:00 AM by Tom-s »
Offline Jamier
Reply #5 on: October 07, 2018, 05:18:42 PM
PB, where is Caucasian Blackplate and what have you done with him?
Jamie
James Robbins
Reply #6 on: October 08, 2018, 05:45:08 AM
IDK, I think perhaps old Doc B is trying to make it easier to herd the Pauls.
Reply #7 on: October 08, 2018, 10:43:01 AM
This is fantastic, thanks! I'd always assumed there was little I could do but this will make my life much easier.
I've gone for the 50k attenuator as I can't seem to find a 100k one readily available anywhere (unless someone can point me in the right direction?).
One question on the volume resistor mod - I plan on eventually upgrading to some HD800sm with have a much higher impedance (300 vs 120). Presumably if I do this it's simply a case of reversing the resistor mod?
Thanks all!
Offline Tom-s
Reply #8 on: October 08, 2018, 11:02:37 AM
Yes. It's reversible if needed.
Reply #9 on: October 08, 2018, 01:26:55 PM
Headphone impedance will not on its own require the removal or installation of the resistor mod to the attenuator.
