Stereomour II 45 Conversion - Anyone Do It Yet?
Sugar Man · 99558
Reply #120 on: October 27, 2019, 06:49:38 AM
The manufacturer indicates that about 10V from the amp will be adequate for the LCD-4.  You won't get this from a #45 amp or a #45B amp unless you get custom wound output transformers with higher impedance taps to make more power available.
I did some more reading this morning that i think clears this up. IN a FAQ, Audeze explains that the higher Watts recommendation is for transients. That makes sense to me since, according to a couple of online calculators I checked, the 97 dB/mV sensitivity of the LCD4 only requires 63 mW to get to 115 dB - which is pretty loud.
Lundahl makes a headphone output transformer tapped for 4.6K/32, 5.4K/150 and 5.4K/600 ohms: LL2765. Assuming I can get it made for parafeed, do you foresee any problems with trying it?  Datasheet attached.
I'd be curious to hear how the SII-45 performs driving the LCD4 with a ton more headroom.  The impedance/frequency plot of phones is nearly ruler flat, so I'm thinking the loss of damping with the secondaries wired for 150 ohms might not be a big deal.  But I suspect I'd need to pad down the signal, but not sure where in the BeePre -> SII-45 chain.
If it is workable, I could convert the SII-2A3 to run regular 45s with the LL2765, and compare it to the SII-45 rebuild for EML 45B.  I think that would be cool.
cheers and many thanks, Derek
Reply #121 on: October 27, 2019, 06:53:29 AM
With 7W dissipated, that will be 75C rise, so you'll see a constant 100C during operation.  This is the absolute maximum dissipation that you could really run on these for very long, and putting the Crack over a laptop cooler to circulate air with fans will be a very good idea.
Hmmmm. Thanks for this PB. But I'm not sure I want to venture into the territory of potentially destructive testing! I'm not using the Crack but I'd like it to survive that so my son can use it down the line.
cheers, Derek
Reply #122 on: October 27, 2019, 08:54:35 AM
You can play a 60Hz tone into your headphones that sounds "loud" and measure it with your AC volt meter and make this determination yourself.
Yes, noise.  The 32 ohm output might be quiet enough.  I'd also want to see frequency response measurements for each of those secondary configurations.
Damping won't be a big deal, but noise will be.
I'm getting the impression that you should just use the Kaiju.  It has the power you need and doesn't require a tube that one random company makes.
Reply #123 on: October 27, 2019, 09:49:51 AM
Many thanks PB.
Yes, true. But I don't have a problem get loud enough. I'm just curious about whether more power for split-second transients is noticeable.
Quote
Thanks, that's helpful. Does one component in particular contribute to the noise - e.g., is this heater/filament noise?
Quote
The Kaiju's definitely not going anywhere. And just be clear: I don't think there is anything wrong with my SII-45. This is project is mostly just for the fun/learning to be had: I want to see whether the SII-45 can be brought closer in performance to the Kaiju with my favorite 45 tubes, the EMLs (whether they are technically "45" tubes does'nt much concner me - they are drop ins for a regular 45 and to my ears sound better).
cheers and thanks, Derek
Reply #124 on: October 27, 2019, 10:25:44 AM
If "loud" is 0.5V vs. 5V, doesn't that provide a ton of information for you about how critical more transient power would be?
The #45.
Reply #125 on: October 27, 2019, 11:44:29 AM
I'm just interested in testing Audeze's argument for having tons of power on tap: the brain interprets millisecond loud transients (e.g., 30-50 dB louder) that form the leading edge of notes/sounds as part of what makes things sound "realistic". Their argument can be found here: http://www.audeze.com/blogs/technology-and-innovation/sensitivity-impedance-and-amplifier-power I understand them to be suggesting that the transient edge, because of its super short duration, doesn't register as "loud" in the brain, but as part of what the brain expects as part of the sound of something real (drum hit, hand clap, etc.). I'm not saying Audeze is right - but that seems to be why they say tons of excess power is necessary.
Quote
The #45.
Ah. Thanks. So the noise in inherent to the tube structure/performance itself.
cheers, Derek
Reply #126 on: October 27, 2019, 03:03:30 PM
I'm just interested in testing Audeze's argument for having tons of power on tap: the brain interprets millisecond loud transients (e.g., 30-50 dB louder) that form the leading edge of notes/sounds as part of what makes things sound "realistic". ...
Lots of people say this. Recordings, however, virtually never capture more than 14-20dB of the transient peak. So OK, if you have your own microphones in Symphony Hall, and run your own wire from there to your living room, then this might be relevant.
Reply #127 on: October 27, 2019, 03:45:14 PM
Thanks PJ - On reflection, that makes immediate sense. I imagine that even with the microphones, capturing the full peak of the transients might be a challenge. I don't know anything about recording technology, but assuming mics make use of some sort of logarithmic translator of sound pressure to voltage signal, the receiving membrane would have to be insanely engineered to be able to deal with both low level and ultra-high level sound.
Reply #128 on: October 27, 2019, 07:17:46 PM
I looked up my notes - the OT-2 (Stereomour/SEX output transformer) operating as an 8K transformer (SEX) saturates about 2.4 watts at 25Hz, which is 4.8 watts at 35Hz or 9.6 watts at 50Hz. At 4K ohms (Stereomour), it's 2.4 watts at 18Hz, 4.8 watts at 25Hz, 9.6 watts at 35Hz, and 19.2 watts at 50Hz. Measured inductance was 45H at 350 Gauss, gradually rising to 265H at 7000 Gauss (as high as I could go at the time).
For comparison, OT-5 in Kaiju at 3K ohms is good for 8 watts at 22Hz.
These calculations are for 29-gauge M6 grain-oriented silicon steel at 13,500 Gauss flux density - moderately conservative since power transformers will sometimes push the M6 flux density to 16,000 Gauss.
A quick look at that Lundahl shows the primary is always the same, at all nominal impedances - only the secondary taps change. That's exactly the same as OT-2. Looks like it will handle about 10 times as much power as OT2 at any of the above impedance/frequency combinations. I see a rated 150 henries for the small gap (parafeed), but at an unspecified flux density. It's common to measure this at a high flux, but I don't know how Lundahl does it.
I estimate from the specs that Lundahl does their power rating at 16,000 Gauss, which is about 40% more power than 13,500 Gauss, but - again - I don't have specs on their core material, and I'm making some guesses.
Reply #129 on: October 28, 2019, 02:42:18 AM
Many thanks PJ.
I have emailed Lundahl and inquired about this. From what I read, going to amorphous core roughly doubles the inductance but also greatly increases the saturation and so reduces power handling - but with all that extra power handling available, I think this should be OK. Hopefully Lundahl will respond with answers.
Reply #130 on: October 28, 2019, 08:08:26 AM
I've heard back from Per Lundahl. No specs for Gauss, and nothing specific for parafeed or amorphous core, but maybe this can be calculated/estimated from the info he provides? He states:
"The primary inductance for LL1679/PP(silicon iron core) is 150H  with 25u airgap, so the inductance for the AM core in PPZ (0u airgap)  should be at least 150H or higher. Measured at no DC component, 50Hz, approx. 100V RMS signal swing."
Reply #131 on: October 28, 2019, 08:15:58 AM
So... Sowter 8983?
Reply #132 on: October 28, 2019, 08:27:58 AM
And in case it is relevant, here's what Lundahl says (online) about the difference between silicon steel and amorphous core versions of its transformers:
"The obvious measurable difference between our silicon-iron cores and amorphous cores is that the saturation flux for the amorphous core is approximately 33% less than for the silicon-iron counterpart. This is caused partly by a lower saturating flux level, partly by a smaller fill-factor due to the thickness of the amorphous sheets. As a result, power bandwidth is reduced by about 50%. (This means that if the max output power for a standard LL1620/40mA is 25W at 30 Hz, corresponding max. power for LL1620AM/40mA is 13W.)"
Reply #133 on: October 28, 2019, 08:32:36 AM
So... Sowter 8983?
I am clueless here. You guys left me in the dust as soon as the discussion went beyond my understandings that (a) other things being equal, bigger = more power, less saturation, and (b) amorphous may sound nice, like mumetal
I'm hoping PJ will jump in with more of his insight.
Reply #134 on: October 30, 2019, 06:45:12 AM
Yeah, that was a blast of information without enough context. Apologies.
I was basically trying to assess the operation of OT-2 at 8k ohms impedance and high power. Bottom line - to compare with Lundahl, one should use the same saturation flux density and frequency. Lundahl uses 30Hz, and I estimate from their specs that they use 16kGauss. Under those conditions, OT-2 can handle 4.85 watts.
