DC and AC Voltage on Chassis when Headphones plugged in [resolved]
johnolaugh · 1176
Offline johnolaugh
First build, everything looks great.  All resistance and voltage checks are good.  When I insert a 1/4 adapter into the headphone jack (testing with crummy earbuds), I get voltage on the chassis.  It goes back to ground when removed.  I did continuity checks on every point that should be a ground, and everything
240vDC and about 6VAC.  Kind of scratching my head.  Has anyone dealt with this and or is this is how the circuit is designed.
EDIT: PENDING REPAIR... Possible Discovery of issue.
« Last Edit: November 25, 2018, 02:10:49 PM by Paul Birkeland »
Offline johnolaugh
Reply #1 on: November 25, 2018, 10:47:24 AM
Was missing a junction on the headphone jack, I did not follow instructions properly and did not junction the bottom lugs together hence the absence of a ground when the headphones were inserted.
Fun builds never leave you with 100%  success.
