230V or 240V configuration
JJPOD · 2206
Offline JJPOD
on: December 04, 2018, 03:22:44 AM
Hello all-
In the middle of building and wanted to ask advice.  I checked the voltage output from the wall to determine the transformer voltage wiring configuration.  The voltage is 230V at home, and 242V at work. Is there a best configuration to enable amp use in both places? Would users suggest the 225<V<235 or the 235<V<245 configuration?
thanks in advance!
Reply #1 on: December 04, 2018, 04:32:11 AM
Where do you plan to do most of your listening?
Offline JJPOD
Reply #2 on: December 04, 2018, 05:27:18 AM
At home where the voltage is 230.  However, I am building the amp at work where the voltage is 240.  If I wire the configuration for 225<V<235, should I be concerned about damaging any of the components while while building/conducting voltage checks when plugged into 240V?
Reply #3 on: December 04, 2018, 05:30:30 AM
You won't damage anything by doing that, but some of your DC voltages are going to seem a little high.
Offline JJPOD
Reply #4 on: December 04, 2018, 06:39:45 AM
Thanks for the input.  I'm glad to know that the transformer wont be damaged.
