Output switch (one in, three out) question
Jameson · 3523
Offline Jameson
  • Intern in Chief
on: February 21, 2019, 09:04:00 AM
Hey all. I'm looking to build a one input, three output switch. I think I have it figured out, but would love feedback. In this diagram I'd use a two pole, three way make-before-break (shorting) switch and four each of red and black RCAs. Do I have the wiring diagram in the attachments correct? Do I need a ground anywhere?
« Last Edit: February 21, 2019, 09:10:45 AM by oguinn »
Jameson O'Guinn
Managing Partner
Reply #1 on: February 21, 2019, 09:41:36 AM
I think you need a 4 pole 3 position switch. Just reverse the SII setup.
Reply #2 on: February 21, 2019, 09:43:50 AM
And I think you want a non-shorting switch.
Offline Jameson
  • Intern in Chief
Reply #3 on: February 21, 2019, 09:46:23 AM
Ok, interesting. I found the two pole, three position recommendation here: https://bottlehead.com/smf/index.php?topic=4065.msg37258#msg37258
And I got the shorting switch guidance from a few different DIY forums, but I obviously could have gotten that wrong.
Four pole does make more sense, I guess. One ground and one signal for each RCA?
« Last Edit: February 21, 2019, 09:59:02 AM by oguinn »
Jameson O'Guinn
Managing Partner
Reply #4 on: February 21, 2019, 10:00:11 AM
I think the shorting switch is used for stepped volume control. I have a drawing I used for adding 2 input with a blank spot in the middle. I'll try to adapt it, give me a few...
Offline Jameson
  • Intern in Chief
Reply #5 on: February 21, 2019, 10:01:00 AM
Ah that makes sense. Thanks for modifying your drawing!
Jameson O'Guinn
Managing Partner
Reply #6 on: February 21, 2019, 10:29:00 AM
It may be a bit confusing, I used the colors that come in a CAT5 cable, so I had to double up a couple of colors, the dotted lines are the white striped wires. The center A is internally connected to 1-3, depending on the switch position. B goes to 4-6, C to 7-9 and D to 10-12. So the first position activates 1,4,7 & 10. The 2nd activates 2,5,8 & 11 and the 3rd 3,6,9 & 12. (The way I hooked up + & - to A-D isn't the same as BH used, but It worked for me)
Offline Jameson
  • Intern in Chief
Reply #7 on: February 21, 2019, 10:36:21 AM
That's awesome, thank you Karl.
Jameson O'Guinn
Managing Partner
Offline Jameson
  • Intern in Chief
Reply #8 on: March 19, 2019, 05:53:59 AM
Update on this. I finally got the chassis plate milled by Front Panel Express and then powder coated locally. Thankfully I tried out the wiring diagram before I committed to soldering it.
Later today I'll solder it up and then toss it into a base.
Jameson O'Guinn
Managing Partner
