Voltage Issues LEDS
Mesz77 · 16099
Offline Mesz77
Reply #15 on: March 04, 2019, 08:22:47 PM
Resoldered to no luck. Switched the tubes to some luck. Switched the tubes and it works perfect. Switched the tubes again and it works perfect  ;D
Brandon Meszar
PSU
Reply #16 on: March 05, 2019, 04:24:29 AM
This suggests poor solder joints on the sockets or on the other end of anything soldered to each socket.
Offline Mesz77
Reply #17 on: March 05, 2019, 05:44:20 AM
So just resolder A1-A9 and anywhere they lead to?
Brandon Meszar
PSU
Reply #18 on: March 05, 2019, 05:54:46 AM
Yes.
Offline Mesz77
Reply #19 on: March 05, 2019, 06:29:20 AM
Resoldered all of those. Made sure there was no cold soldering and that there is a healthy amount of solder on the wires. Everything felt sturdy and solid after resoldering. Plugged the preamp in and only got the LED for A3 to light up. Switched the tubes and now both LEDs are lit but are continuously flickering. I guess just keep messing with A1-A9 and anywhere they lead until it works?
Brandon Meszar
PSU
Reply #20 on: March 05, 2019, 08:51:30 AM
You can also send it in for repair and we will fix the joints for you.
Offline Mesz77
Reply #21 on: March 05, 2019, 10:22:50 AM
Will try my hardest to fix it, but having no experience I'll probably end up biting the bullet and sending it in for repair. Thank you for all your help!
Brandon Meszar
PSU
