Bottlehead Kits
Crack
Need help trouble shooting voltages
Incendie
5725
3
Incendie
Jr. Member
Re: Need help trouble shooting voltages
Reply #15 on:
April 15, 2019, 05:09:44 PM
You're right. I redid the voltage checks and realized that I must have been reading it as VAC instead of VDC because here are my results:
T1 - 71V
T2 - 192V
T3 - 0V
T4 - 192V
T5 - 77V
T6 - 0V
T7 - 117V
T8 - 0V
T9 - 111V
T10 - 0V
OA - 70V
OV - 77V
G - 0V
B+ - 192V
Paul Birkeland
Global Moderator
Hero Member
Reply #16 on:
April 15, 2019, 05:12:08 PM
That is a working set of voltages. Buzzing would usually be caused by a loose connection (some of them can be loose and not alter the DC voltages) in the amp. Sometimes loose hardware can also allow this to pop up.
Incendie
Jr. Member
Reply #17 on:
April 15, 2019, 05:12:57 PM
I just plugged it back in and my right side is still dead. Any ideas as to why?
Incendie
Jr. Member
Reply #18 on:
April 15, 2019, 05:21:13 PM
Actually, I noticed that if I slowly try to plug the jack in, it's perfect about 3/4 of the way down.
Incendie
Jr. Member
Reply #19 on:
April 15, 2019, 06:13:48 PM
Nevermind, it loses stereo audio and the left channel feeds to both that way.
Doc B.
Administrator
Hero Member
Reply #20 on:
April 15, 2019, 06:45:00 PM
If your voltages now measure OK the next place to start looking is in the signal path. Check over the RCA jacks to be sure the right one hasn't had a wire break. This can happen sometimes when an interconnect cable is inserted or removed if the jack is a little on the loose side. If that is all OK move on to the volume pot and make sure there are no cold solder joints or shorted wires.
Incendie
Jr. Member
Reply #21 on:
April 16, 2019, 05:23:46 PM
https://photos.app.goo.gl/KD8iyWniNVbf2Hdt8
I checked and reflowed most of the red wire connections, but still nothing. Tried to take a few photos of the connections. I even checked that there's no resistance along the red wire coming from the right (red) input to the lug on the POT.
Paul Birkeland
Global Moderator
Hero Member
Reply #22 on:
April 16, 2019, 05:38:06 PM
The red wire going to the center pin of the RCA jack is not soldered. There is solder there, but it's not flowing around the wire. There could be enough flux in there that the wire is totally insulated.
Incendie
Jr. Member
Reply #23 on:
April 16, 2019, 06:09:43 PM
https://photos.app.goo.gl/DE6sCWSFJeLZC6UF8
Re-did it and still nothing in the right side
Paul Birkeland
Global Moderator
Hero Member
Reply #24 on:
April 16, 2019, 07:39:19 PM
I was looking over your photos and noticed that the 2.49K resistors on the headphone jack are a bit charred. Was there an issue with the initial build that caused this? If you plug in a 1/4" to 1/8" headphone adapter but no headphones, what DC resistance do you get from ground to 6 and ground to 10?
Incendie
Jr. Member
Reply #25 on:
April 17, 2019, 01:08:18 PM
I actually didn't notice that they were discoloured like that and I don't remember there being any issues that may have caused that. I'm away from it right now, but last I checked the resistance was 2.45k because that was what caused the original mixup in the resistance checks earlier in this thread.
Paul Birkeland
Global Moderator
Hero Member
Reply #26 on:
April 17, 2019, 05:01:45 PM
There's another set of tests we can do if your meter has a reasonable number of AC scales. Can you post the model of your meter?
Incendie
Jr. Member
Reply #27 on:
April 17, 2019, 05:06:46 PM
Mastertech MAS830
Paul Birkeland
Global Moderator
Hero Member
Reply #28 on:
April 17, 2019, 05:11:04 PM
Yeah, the 200V AC range won't resolve what needs to be measured. The $20 meter at Harbor Freight will do the job, or if you can borrow one with a 2V AC scale, we can send a tone into your amp and measure where it doesn't exit.
Incendie
Jr. Member
Reply #29 on:
June 04, 2019, 01:07:41 PM
It took me a while, but I finally got my hands on a new multimeter, the MTP 2322. Let me know if this would be suitable and what needs to be done next.
3
Bottlehead Kits
Crack
