Less gain than SEX?
Jameson · 2728
Offline Jameson
  • Intern in Chief
on: May 21, 2019, 01:28:38 PM
I finished the Stereomour II today and started testing it (very limited tests so far). With everything the same, it seems to have a good amount less gain than the SEX with C4S. Is that to be expected or is there a possible issue?
Jameson O'Guinn
Managing Partner
Offline Jameson
  • Intern in Chief
Reply #1 on: May 21, 2019, 01:40:11 PM
It seems like the SEX has a gain of 15 and the Stereomour has a gain of 8, so that seems to track with what I’m seeing (as long as I’m reading that right and understanding it).
Jameson O'Guinn
Managing Partner
Reply #2 on: May 21, 2019, 01:42:01 PM
Are the impedance taps set the same between both?
I see 15dB of gain for the SEX on the 8 ohm OT configuration, which IIRC doesn't go up a whole ton with the C4S upgrade.  I roughly calculate that the Stereomour would be a few dB below that.  If you'd like to increase the gain of the Stereomour a bit, you can install cathode bypass caps on the driver cathode bias resistors.  2200uF at 6.3V would be my recommended starting point.
Offline Jameson
  • Intern in Chief
Reply #3 on: May 21, 2019, 01:46:09 PM
I believe I had them both wired for 8 ohms. I’ll double check when I get home.
I might do the cathode bypass caps after some listening time. If I do I’ll 100% need some help understanding what that means and how to do it.
Jameson O'Guinn
Managing Partner
Offline Jameson
  • Intern in Chief
Reply #4 on: May 21, 2019, 01:53:06 PM
If I go that route, I assume these caps are sufficient. Any concerns?
https://www.mouser.com/ProductDetail/647-UKL0J222KHD
Jameson O'Guinn
Managing Partner
Reply #5 on: May 21, 2019, 02:33:02 PM
The cathode bypass caps will make a very small difference - I calculate 0.7dB.
My calculations show a gain of 7.08 (17dB) for SEX with C4S, and 4.5  (13.1 dB) for Stereomour II, both set for 8 ohms. Note that they use the same output transformer, but at different impedance levels, so the 8-ohm wiring is different between them.
Offline Jameson
  • Intern in Chief
Reply #6 on: May 21, 2019, 02:39:17 PM
I think it’ll be loud enough for my current room. I’ll revisit in the future if it becomes an issue.
I have a handful of those caps on the way just in case, although it sounds like they won’t make much difference.
Jameson O'Guinn
Managing Partner
