Oh boy... Crack killed my headphones
carlman14 · 5080
Reply #15 on: June 12, 2019, 09:16:34 AM
Nope, a tube arcing over at startup is not normal. It is the indication of either a bad tube or some problem in the circuit. That said, it is not a bad idea to start the Crack up and let it warm up for a bit before plugging in headphones if you are unsure of the amp's or tube's behavior.
Offline carlman14
Reply #16 on: June 12, 2019, 09:44:34 AM
Gotcha. Not much else to blame except my soldering skills  ;D
If anything, this has been a good learning experience. Thanks for the response.
