Floating Ground
Jamier · 6055
Offline Jamier
on: June 22, 2019, 07:00:08 AM
I’m working on an amp that, by design, has a “floating” ground.I’m thinking I should Earth ground the input shields since tying them to the circuit ground will probably not accomplish what I want ( noise rejection). Is this correct?
Jamie
« Last Edit: June 22, 2019, 10:19:38 AM by Jamier »
James Robbins
Reply #1 on: June 23, 2019, 10:18:03 AM
You should consider providing a whole lot more info about what you're working on.  Connecting shield grounds to audio ground does tend to defeat the purpose of the shield in the first place.
Offline Jamier
Reply #2 on: June 23, 2019, 10:42:56 AM
I was given a pair of K-501 boards by a friend. I built chassis for them with the intention of mounting the inputs off board. I have mounted RCAs on the chassis which require an input cable run of about 4 inches. The connection for the inputs,on the board, is about 4 inches from the PT. I concluded, possibly erroneously, that I should use shielded cable to connect the RCAs to the board. The circuit ground floats so I figured, possibly erroneously, that grounding the shield to the circuit ground would have no effect. At this point I intend to ground the shields at the ground on the IEC, but I do have concerns that they will pick up noise from the adjacent AC input.
Jamie
James Robbins
Reply #3 on: June 23, 2019, 02:37:58 PM
At the IEC, connect the ground straight to the chassis.  Wherever you have cable shields, connect them at the load end to the chassis.  I would either connect the audio ground to the chassis right where that signal cable enters the board, or use a pair of anti-phase diodes to tie the audio ground to the chassis.
Offline Jamier
Reply #4 on: June 24, 2019, 12:01:36 PM
PB, I don't have any 2A diodes but I have a crapload of 1A uf4007s. Can I parallel 2 of those in each direction, or is that a  no go?
Jamie
James Robbins
Reply #5 on: June 24, 2019, 01:10:10 PM
You want the diodes to be able to blow the fuse if the SHTF.  I suspect a UF4007 would still blow a 1A fuse without trouble.
Offline Jamier
Reply #6 on: June 24, 2019, 01:34:26 PM
PB, So should I parallel 2 uf4007s in each direction, or just use 1 in each direction?
Jamie
James Robbins
Reply #7 on: June 24, 2019, 01:37:32 PM
You could try it both ways.
If there's a local electronics shop, the diodes don't have to be anything particularly special.
Offline Jamier
Reply #8 on: June 24, 2019, 01:43:04 PM
What about a 2A fuse?
Jamie
James Robbins
Reply #9 on: June 24, 2019, 01:44:04 PM
What is the current fuse value?
Offline Jamier
Reply #10 on: June 24, 2019, 02:00:02 PM
In don't know. I'm away from it at the moment. Do you have formula for calculating the diode rating.
Jamie
James Robbins
Reply #11 on: June 24, 2019, 02:05:51 PM
Yes, you look at the datasheet for the diode and read the number for forward current.
Offline Jamier
Reply #12 on: June 24, 2019, 03:55:31 PM
Peak or average? I figure your going with average, right? So if I do have a 2A fuse, I probably need to use 4A diodes in anti-parallel to insure that the 2A fuse will fail if the SHTF?
Jamie
James Robbins
Reply #13 on: June 24, 2019, 04:01:58 PM
I would stick with average.  You don't want the diode to blow with the fuse!
Offline Jamier
Reply #14 on: June 24, 2019, 04:19:29 PM
So, am I correct? Or?
Jamie
« Last Edit: June 24, 2019, 05:08:11 PM by Jamier »
James Robbins
