Powder Coated Crack Grounding
Blooze · 3656
Offline Blooze
    • My Electronics Pics
on: August 07, 2019, 05:29:33 AM
I had the top plate and trafo bell powdercoated (they coated all surfaces, was going to cost a fair bit more if they masked anything).  I just want to confirm that I need to scrape the coating off the bottom of the plate at terminal 3,8, and the #8 safety ground bolt? Any other places? The transformer is isolated from the top plate so I don't need to worry about scraping any off the underside of the bell or plate on those 4 holes, correct? Possibly run a 1/4" drill bit by hand through the top plate transformer mounting holes if the fiber washer shoulder doesn't fit?
Thanks for any help!
Reply #1 on: August 07, 2019, 05:37:49 AM
You don't need to worry about terminal 8, but certainly 3 and the ground screw.  Passing the 1/4" drill bit through those holes is a good idea, as the shoulder washers are a tight fit. I would also scrape off a bit of the coating on the bottom side of the transformer cover around each hole.
Offline Blooze
Reply #2 on: August 07, 2019, 03:07:49 PM
Here's what I have so far. I sure hope the bell doesn't end up rusting in those spots.  It was $30 just to get the bell coated.
« Last Edit: August 07, 2019, 03:09:42 PM by Blooze »
Reply #3 on: August 07, 2019, 03:21:17 PM
Nice color scheme! That is going to look great. Post pics when you're done. What do you have in mind for the base?
cheers, Derek
Offline Blooze
Reply #4 on: August 07, 2019, 03:34:26 PM
A dark walnut or coffee with a gloss finish. I’m going to try and cut a 1/8” kerf about 3/16” from the top (or bottom of the supplied boards) and make the rear panel removable using cross dowels and bolts.  Unfortunately my router died on my trial piece so I’ll need to replace it first as I don’t have a table saw to cut the kerf.  That way the top plate is locked in the base. I can then put a clear plexiglass bottom with vent holes on.
Reply #5 on: August 07, 2019, 03:51:23 PM
Nice. So you can just slide the chassis in/out. Very cool idea.
Word of caution: you should run the idea of plexiglass with holes by PB - I imagine that might seriously cut down on convection cooling even if you made it 50% holes. If it's a no go for cooling reasons, maybe a mesh screen instead?
Offline Blooze
Reply #6 on: August 07, 2019, 04:05:58 PM
Very true. I thought about a metal mesh bottom. I’d like to make it non-conductive if possible, just for safety’s sake.
Reply #7 on: August 07, 2019, 04:14:40 PM
You scraped 8, but not 3.  You need to scrape 3, but not necessarily 8.
Offline oguinn
Reply #8 on: August 07, 2019, 04:22:16 PM
I had my powder coating done at a motorcycle repair shop. I think he charges me $20 for the plate, bell, and any other shields or clamps I bring in. You might try finding one, too. You can see pics of my stuff (and a couple other people) at my gallery site.
Jameson O'Guinn
Offline Blooze
Reply #9 on: August 07, 2019, 04:38:23 PM
The nearest powder coating to me is almost three hours. These folks were the cheapest. It was $70 for the cream plate and the ruby flake bell.  If they’re in the US I should just mail them my stuff. Probably still be cheaper.
« Last Edit: August 07, 2019, 05:04:53 PM by Blooze »
Offline Blooze
Reply #10 on: August 07, 2019, 04:39:00 PM
And that’s why I don’t even sand paint off when I’m tired. Jeesh 🙄
« Last Edit: August 07, 2019, 04:55:16 PM by Blooze »
Reply #11 on: August 07, 2019, 06:03:43 PM
Yeah, it would have been enough to scrape the bottom side of the transformer cover, not the top side.  I would dab a little bit of clear coat over those spots, as they will probably rust.
Offline Blooze
Reply #12 on: August 07, 2019, 06:06:28 PM
That is the bottom side 😁. Pic makes it hard to see.
Offline oguinn
Reply #13 on: August 07, 2019, 06:27:24 PM
I’m happy to pass along my guy’s information if you need more stuff powdercoated. My wife would love that color combo, by the way, since she’s an Oklahoma Sooner.
Jameson O'Guinn
Offline Blooze
Reply #14 on: August 08, 2019, 03:11:08 AM
That’d be great if you could share the contact info.
Paul, is there any worry about the bottom part of the bell where I scraped rusting? Maybe a dab of thin primer that the washer can easily bite through?  It definitely wasn’t biting though the powder coat as I cranked down a toothed washer and checked before scraping any off.
