New Eros 2
adeep42 · 6120
Reply #16 on: August 23, 2019, 07:57:16 AM
You can use a pair of clip leads to connect the center pins of each RCA jack to ground in the amp.
Offline adeep42
Reply #17 on: August 23, 2019, 08:25:45 AM
Strike out. No change
Reply #18 on: August 23, 2019, 09:45:27 AM
You said you had another Eros floating around, does it exhibit these symptoms?
Offline adeep42
Reply #19 on: August 24, 2019, 08:32:24 AM
The other Eros is not just floating around. It's in my main system attached to 2 turntables with a switch that I made with your and Doc's and Paul Joppa's help back in August of last year. The reason I made the switch was that I really love the Eros and didn't want to replace it when I added the second turntable.
As per your suggestion, Eros No. 1 is now in the system that I wanted the new Eros 2 for. Not an iota of hiss, crackling, popping. Just beautiful music.  Ergo, the noise is not environmental.
Stumped again. Very baffling.
Alan
Reply #20 on: August 24, 2019, 08:38:43 AM
Well, you are welcome to send it back and I can look it over again.  It's possible that there's a solder joint that just isn't 100% perfect and the shipping process is enough to disturb it.
Offline adeep42
Reply #21 on: August 24, 2019, 09:18:37 AM
Think I'll set up shop again and try to reflow as many joints as I can reach easily on the left side. Then we can re-evaluate.
Thanks as always,
Alan
