High vs Low Impedance Setting
adydula · 2447
Offline adydula
on: September 19, 2019, 07:22:04 AM
So please help me understand the ramifications of using this switch.
I think its a hey if your headphones are above a certain impedance then use high, below a certain range use low?
If you use the amp on say a low impedance set of headphones ie 55-60 ohms on high setting, what should one notice vs using it on a low setting
with these impedance cans?
Alex
Reply #1 on: September 19, 2019, 07:32:56 AM
For headphones which are very sensitive (Grados, IEMs, etc), the low impedance setting will provide a blacker background.  It will also provide lower distortion and better damping, especially into low impedance headphones.
The high impedance setting will provide more power out of the amp provided the headphones used are not low impedance headphones.  The trade-off here is a slightly higher noise floor and a bit less damping and potentially more distortion.  If you are using a 100+ ohm headphone on the high impedance setting, odds are you won't hear the difference in noise, nor the increase in THD and decrease in damping.
If you have super sensitive 16 ohm IEMs, you may very well be able to here these changes more easily.
