High OB voltage and 1 LED doesn't light up [resolved]
Jimb0 · 2119
Offline Jimb0
on: September 24, 2019, 06:39:48 PM
Getting 170v at OB and the LED at A8 to Center Pin doesn't light up
« Last Edit: September 26, 2019, 12:38:42 PM by Paul Birkeland »
Reply #1 on: September 24, 2019, 07:08:13 PM
Resolder the center leg of the MJE5731A on that side.  If that doesn't work, posting some photos of the area could be helpful.
Offline Jimb0
Reply #2 on: September 25, 2019, 08:46:21 AM
Still getting the same readings
Here are some pics
Reply #3 on: September 25, 2019, 08:55:25 AM
Did the amp pass its voltage checks with the plate load resistors?
If this was built with the Speedball from the beginning, this could be an issue of the solder joints at A4/A5 not being solid.
Offline Jimb0
Reply #4 on: September 25, 2019, 09:36:48 AM
I built the amp with the Speedball from the beginning.
I resoldered A4/A5 but to no avail, same readings
Reply #5 on: September 25, 2019, 10:04:29 AM
Is the voltage at A8 0V or 12V?
Offline Jimb0
Reply #6 on: September 25, 2019, 11:20:53 AM
A8 is at 14v
Reply #7 on: September 25, 2019, 02:43:55 PM
The LED needs to be replaced.  Sometimes they can fail from heat or pulling on the leads tightly, or if they sit in a humid environment they can end up like this once you solder them.
Offline Jimb0
Reply #8 on: September 26, 2019, 11:03:29 AM
Thanks PB! Everything is in order now.
